I need help
Old Sep 22, 2002 | 06:11 PM
sleepercivic's Avatar
Default Need Help ASAP!!!!!!
Here are my symptoms
-no VTEC i changed the solinoid and then now it wont werk at all before it was hit and miss and would not work all the time
-Sputtering top end when idown shift into second- this is most likely the plugs as last night it wuold let me go over 4 grand
-Idles bumpy
-MAP is throwing a code and so are my injectors which are wired to a resitor box
this all happened after i turboed
my setup is Hondata stage 3b b16block 9:1 compression 450 DSM injectors
any ideas please help me i need this running so i can race on the 29th!!!
TERRY
[Modified by sleepercivic, 3:59 AM 9/23/2002]
Old Sep 22, 2002 | 06:13 PM
Default Re: I need help (sleepercivic)
i had a thought on the MAP as maybee i boosted over 11 psi and it messed it all up? could this happen?
also if the injectors are hooked up wrong would they still work on the resistor box.
also does anybody have a good website to get a wiring harness diagram for a 92-95 dx and si?
and could not having a ground on the valve cover be doing any of this
TERRY
Old Sep 22, 2002 | 07:21 PM
any body have anythoughts
TERRY
Old Sep 22, 2002 | 07:24 PM
rjardy's Avatar
I'm guessing that your hondata is tuned right?
Rob
Old Sep 22, 2002 | 07:46 PM
Default Re: I need help (rjardy)
not tuned yet, Payn tech told me to fix my problems before we tune so thats what im trying to do it has a tuned for a turbo b16 with 450 injectors
TERRY
racingsoul
May 7, 2006 07:37 PM
Vadian
Jul 30, 2003 05:31 PM
sleepercivic
Sep 23, 2002 05:18 PM
