How high can you boost on a 00 gsr b4...
Re: How high can you boost on a 00 gsr b4... (NHB Fighter)
usually 30-32 lbs....right around 32lbs it throws code 711 "to much pressure in intake, danger to welds"
Re: How high can you boost on a 00 gsr b4... (NYb16)
Re: How high can you boost on a 00 gsr b4... (01geeser)
oh really....then I have nothing to worry about!! No but really, how high because the 2000 gsr with obdII "enhanced" has a lot of restrictions and I'm gonna be turning up the boost quite a bit.
Uh.. on a stock MAP sensor I believe any sign of boost will throw a code, someone correct me if I'm wrong? Otherwise, you'll need a 3 bar MAP sensor after like 11 lbs. or so.
Re: How high can you boost on a 00 gsr b4... (Cow)
Re: How high can you boost on a 00 gsr b4... (98civicEX)
stock map sensor cant see even a hint of boost....need the missing link. if you want to boost over 12psi you need the GM 3 bar map sensor.
the max i plan to be boosting will be around 12 wiht spiking up to 14 or so because I have a mbc so would I need this GM 3 bar map sensor? And if I do where can I get one?
