My dyno plots/ please help critique
Old Sep 23, 2002 | 09:07 AM
MIKES's Avatar
Default My dyno plots/ please help critique
B18A block bored 20 over
> Eagle rods
> SRP forged pistons
> TypeR oil pump
> STR blockguard
> ARP head studs
> B18A head ported by JG
> JG 1001 cams
> AEM cam gears both are set at 0
> Skunk2 intake manifold
> 65mm throttlebody
> 450cc injectors
> 3 bar map sensor
> B18A LS tranny
> Stock flywheel lightened
> from 18 pounds to 13
> Clutch Masters Stage3
> clutch and pressure plate
> Aluminum crank pulley
> Walbro 255 intank pump
> B&M adjustable fuel
> pressure regulator (fuel pressure was set at 50psi with the vaccum on)
> JG turbo manifold
> Richard Lee wastegate
> (supports 800hp, took that off my Buick too)
> T3T40E A/R- 60 M-10
turbo
> (Stock Buick Grand National turbo modified)
> 2 1/4 intercooler piping
> Intercooler modified for front mount
> HKS Super Seq Blowoff
> BCPR7ES11 gapped at 30
> Taylor 8 mm wires
> Zdyne Gold ecu with 3 bar map sensor
> After market fuel filter
> to replace the stock junk.
Old Sep 23, 2002 | 09:08 AM
MIKES's Avatar
Default Re: My dyno plots/ please help critique (MIKES)
Sorry no A/F ratio monitor on these pulls.
Old Sep 23, 2002 | 09:12 AM
BLKMamba's Avatar
BMW Güdentyte
25 Year Member
Take out the .org.jpg at the end of your link!
Old Sep 23, 2002 | 09:26 AM
Ri5e's Avatar
Was this at 8 PSI?
Old Sep 23, 2002 | 09:31 AM
MIKES's Avatar
Default Re: My dyno plots/ please help critique (4 Stroke)
13psi
Old Sep 23, 2002 | 11:18 AM
MIKES's Avatar
up
Old Sep 23, 2002 | 12:02 PM
austrian type-R's Avatar
hm, numbers are kinda low dor 13 psi, IMO.
Old Sep 23, 2002 | 12:24 PM
MIKES's Avatar
Default Re: My dyno plots/ please help critique (austrian type-R)
Bro I said critique, not,"hm, numbers are kinda low dor 13 psi, IMO." If you look at the dyno sheet you will understand that power was made at 5400rpm which is very decent seeing how I still have another 2500rpm to go. No Honda shifts at 5400rpm. Thats why I need peeps to CRITIQUE
Old Sep 23, 2002 | 12:44 PM
PROFILES2000's Avatar
he was critiqing
Old Sep 23, 2002 | 12:50 PM
89civic1.8T's Avatar
Default Re: My dyno plots/ please help critique (PROFILEGSR)
I would assume you are running with Steven's B18 Zdyne Tune moded to your fuel setup right? I ran his program on my Stock B18B and pulled 189 WHP/154 Tq
On 8 psi. I then when back to an old program I made while tinkering around and it feels a bit faster. Maybee you should try it. Or course make sure it gives your enough fuel + spark retard. But It made my car feel better. I don't have any #'s for though to prove it.
[Modified by 89civic1.8T, 9:51 PM 9/23/2002]
Old Sep 23, 2002 | 01:40 PM
Mr. Softee's Avatar
Default Re: My dyno plots/ please help critique (89civic1.8T)
Your torque curve sure takes a dive after 5500... seeing thea/f ratio woul really help.
Old Sep 23, 2002 | 01:49 PM
DRAGLS's Avatar
Default Re: My dyno plots/ please help critique (94goldjungsr)
those numbers are real low for a b18b on 13psi heres mine at 14psi on a b18b using a 54 trim to4e w/ a stageIII .48 a/r housing.
Old Sep 23, 2002 | 02:22 PM
degradated's Avatar
New User
He was critiquing. Anyway, sounds like you are satisfied enough with your results, so why would you need any outside input?
Old Sep 23, 2002 | 02:26 PM
qwkteg125's Avatar
Default Re: My dyno plots/ please help critique (DRAGLS)
those were just baseline runs. mike, i'll bet you make more power with some wb tuning. hp shouldn't just go flat after 5500rpms.
[Modified by qwkteg125, 3:26 PM 9/23/2002]
Old Sep 23, 2002 | 03:00 PM
Quick 200k Mile Motor's Avatar
It is a B18A, get it right! Like it really matters,
but I still think old LS motors are better.
B18b owners, your valve cover looks like one for a Neon..just playin'
Old Sep 23, 2002 | 03:04 PM
I wanna critique , but It would help to see the air/fuel ratio vs. rpm graph.
Old Sep 23, 2002 | 04:22 PM
MIKES's Avatar
Default Re: My dyno plots/ please help critique (Quick 200k Mile Motor)
94goldjungsr- The pulls were done without A/F ratio. It was a come as you come and take 2 pulls. But with the wideband the car takes a **** at 5500rpm because of the lack of fuel. So I upped my fuel pump from a Walbro 150 to a Walbro 255. and still the same thing.
DRAGLS- I know they are low thats why I posted my mods so if anybody sees any issues they could tell me something I may have overlooked. But your dyno plot looks good bro. What mods do you have done to yours?
degradated- The graph should speak for itsself. Obviously theres a problem or I wouldn't ask peeps to HELP ME OUT with this issue. I need answers bro. Telling me what I already know isn't helping me. I am not bragging about this by no means I am posting this so someone with turbo experience can see something in my mods that they may question and bring it to the front.
Quick 200k Mile Motor- I would love to show you but that was not a option that day for the A/F. But with the FJO I was reading 15.6 at 5500rpm so I was running lean from 5500rpm onwards.
This question is to everybody. What injector size should I go with? and where does the torque usually tamper off on a LS with my mods?
Old Sep 23, 2002 | 05:00 PM
DIRep972's Avatar
Smarter than you
Whenever people have a problem making power, the first thing i always tell them to look at is their fuel. You need to get that thing on a wideband and get that a/f to 12:1 area. I think u definitly need something bigger then 440cc injectors too, try some 550's.
2nd thing. what size downpipe/exhaust are u running? what is your static compression ratio?
3rd thing. Ur torque curve is falling off bad. Your reaching peak torque later then me and ur torque curve falls off earlier. With cams and headwork your torque should stay alot more flat. your peak torque is right on par where it should be.
I would suggest right now to not worry. First thing I would do is tune the a/f. Then if things arent on par, id look into the possible weak links of the set up. first places i would inspect are intercooler, turbo and cams. considering those 3 things will have a huge impact on what the power curve looks like.
ill try to get my dyno's online asap so u can compare them.
[Modified by DIRep972, 2:01 AM 9/24/2002]
Old Sep 23, 2002 | 06:55 PM
Dam DRAGLS! How didn't you get those awsome #'s! What is your engine setup? Cams, headwork? intake manifold? I have a T3/T04E with a 63 a/r 54 trim compressor but not a stage III wheel. Also I see your A/F takes a dive 5,300 RPMS's And you still made awsome power! Tell us your secret!!
Old Sep 23, 2002 | 06:58 PM
Speed PHreak's Avatar
My fucked up Zdyne tune strikes again......will I ever live down my shame?
Old Sep 23, 2002 | 07:01 PM
TurboInteg95's Avatar
I think you just need some tuning and you'll make more power. Looking at how choppy your power band is thats all i can really tell. You need to get a Wideband on that thing. On my car on 9 lbs of boost with a stock B20 motor I put down 250 hp and 223 ft lbs of torque. You've got all the good parts, just needs some tuning. what are the dimensions of that grand Nat intercooler?
Old Sep 23, 2002 | 07:26 PM
Default Re: My dyno plots/ please help critique (TurboInteg95)
http://www.geocities.com/speed_phreak_88hf/files.htm
Updated, I've got an FJO test bed tune. It's not totally perfect but it works a whole hell of a lot better than that damned conversion I've got such a notoriety for....See if that helps any.
P.S. ~ 40Psi base fuel pressure, GM 2 Bar & 450cc injectors
[Modified by Speed PHreak, 11:27 PM 9/23/2002]
Old Sep 24, 2002 | 03:36 AM
Default Re: My dyno plots/ please help critique (Speed PHreak)
Wow this tune sounds like it was made for may car. I have the same fuel pressure/2 bar map!
Can you send me the file. It's not working for me on the website.
[Modified by 89civic1.8T, 12:38 PM 9/24/2002]
Old Sep 24, 2002 | 05:26 AM
Fixed
Old Sep 24, 2002 | 07:26 AM
MIKES's Avatar
Thanks for for replies guys, this I really appreicate. First thing is first. I have to increase my injector size to 550cc, which a buddy is lending me to see if its enough. 2ndly I have to change my exhaust. I have a 2 1/4 exhaust into a 2" muffler in the stock location of a 91Integra out to a 2" tailpipe. My compression is 9.75 to 1.
Speed PHreak- bro its a learning curve forsure. But I am difenately up for the challenge. Keep up the tuning bro, practice makes perfect.
As for the dimensions of my intercooler, its 25"long 4"thick and 10" in height.
My last question I have for LS turbo guys is, what are you using to vent your crankcase pressure? Are you using the stock setup and a K&N breather on the valve cover? or catch cans and etc?
