Is my boost controller hooked up right?
Old Sep 23, 2002 | 06:40 AM
BoostedD15B7's Avatar
Default Is my boost controller hooked up right?
I put a turbo xs manuel boost controller on my del sol. It works, but i want to check to make sure its hooked up right. Everyone says a mbc allows for faster spoolup, but mine is no faster. And if its set at 10 psi, it will rise then hesitate for a second at like 6 (where wastegates set)then go up to 10 psi. All i did was put it between the turbo and wastegate(boost fitting). Do i leave the wastegate adjustment bolt in there or what? Is the vaccum port supposed to stay open? Heres a pic. not the best, but you can kinda see how its hooked up.
[Modified by BoostedD15B7, 3:47 PM 9/23/2002]
Old Sep 23, 2002 | 07:03 AM
Mr. Softee's Avatar
Default Re: Is my boost controller hooked up right? (BoostedD15B7)
it sounds like you have it right, your picture doesnt work though. And yes you leave the wastegate nut on there.
Old Sep 23, 2002 | 07:47 AM
Default Re: Is my boost controller hooked up right? (94goldjungsr)
hmmmm damn. i see the pic.
B18tSOL
Mar 4, 2007 10:07 AM
integraboosted
Jun 23, 2005 11:59 AM
rbf351
Jan 31, 2003 08:15 AM
SIK IN DA HED
Jun 8, 2002 03:25 PM
Etylorcen
Jun 4, 2002 11:50 AM
