Tial BOV
Old Sep 24, 2002 | 02:33 AM
rjardy's Avatar
Default Tial BOV
Does anyone use the Tial BOV? i have the wastegate 35mm, and I think that it would be nice to keep it all Tial. Anyone know if it works well under medorate boost ~7 to~ 9 psi? How about the sound of it? I am under the impression that it may be for a higher psi application. Thanks everyone
Rob
Old Sep 24, 2002 | 02:40 AM
PROFILES2000's Avatar
Default Re: Tial BOV (rjardy)
you should have no problems at all with the tial at that psi i mean they do offer it in a .5 bar spring which is what im gunna run my daily motor at.
plus they just look sooo much nicer than a delta gate
Old Sep 24, 2002 | 02:50 AM
rjardy's Avatar
OOPS maybe i was unclear, im talkign about there blow off valve. There is a GB going on right now and i think i want to get in on it. Any one use there BOV? Anyone know how it sounds and how it works with about 7-9 psi?
thanks
Rob
Old Sep 24, 2002 | 02:55 AM
DSF's Avatar
DSF
I have one...
...sitting on my bedroom floor Hehe, sorry. I was in the same situation as you. Had the 40mm gate, so I figured I'd get the BOV. With a 50mm valve, it shouldn't have any trouble controlling my planned boost levels and I heard it wasn't "that" loud (a plus for me).
Old Sep 24, 2002 | 02:59 AM
rjardy's Avatar
Default Re: Tial BOV (DSF)
is the quility nice? as good as the wastegate?
what psi are you goign to run?
rob
Old Sep 24, 2002 | 03:03 AM
DSF's Avatar
DSF
Quality is, well, Tial Just like their wastegates as far as construction and materials. I'll should be running 8-12psi on the street and hopefully no more than 20psi at the track
Old Sep 24, 2002 | 03:11 AM
rjardy's Avatar
let me know about the sound when you get it on, i want people to be able to hear mine, but i really like Tial and there stuff is top notch, thats why im leaning toward this one. I want something that i can hear but not get anoying, you know?
rob
Old Sep 24, 2002 | 03:46 AM
DSF's Avatar
DSF
Ok, but it'll probably be a while. I have an engine to put in my daily driver, an engine to install in my boss' car, a house to remodel, then the "beast" get's worked on Ok, there's my sob story
Oh, and I previously had a HKS SSQ BOV and the high pitched whistle which was initially intoxicating began to get on my nerves. With all the recent thefts, I'm trying to be as inconspicuous as possible
Old Sep 24, 2002 | 04:00 AM
rjardy's Avatar
Thanks for all the helpfull info thus far! And i know how you feel about all the theft
rob
[Modified by rjardy, 10:00 PM 9/24/2002]
Old Sep 24, 2002 | 05:02 AM
Anubyss's Avatar
Get the Tial. Nice quality, and the blow off sound is quiet compared to others so less attention to your car (which I find is a plus). I am running 8psi and have no issues with it.
Old Sep 24, 2002 | 06:00 AM
tony1's Avatar
Default Re: Tial BOV (Anubyss)
I had a tial on my integra, very nice piece! It isn't very loud but work very well. It's kinda sensitive though, it needs a really good vacuum source. Don't tee in anything to it and it will work best.
Old Sep 24, 2002 | 12:49 PM
rjardy's Avatar
Default Re: Tial BOV (tony1)
Cool thanks guys, I think that I am probably going to go with the Tial! It just looks so damn nice
Rob
Old Sep 24, 2002 | 01:09 PM
Rain_man's Avatar
New User
I just got a tial bov too. The build quality is great and it looks pretty beefy for just a bov.
Regarding the boost levels that you desire, I talked to Tial and you can swap out the spring so that a lower vaccum will actuate the bov. Yes I do mean the bov, not the wg. But if you are running around 7 psi you probably won't need to do that anyhow.
Old Sep 24, 2002 | 01:20 PM
rjardy's Avatar
Default Re: Tial BOV (DarksideDC4)
sounds good! 7 will be my daily psi most likely maybe a little bit more.
Rob
Old Sep 24, 2002 | 02:52 PM
rjardy's Avatar
Any one else have an opinion on the Tial BOV?
thanks so far guys
Rob
Old Sep 24, 2002 | 04:00 PM
01ITR#700's Avatar
I'm installing mine hopefully in the next few days
M
Old Sep 24, 2002 | 04:10 PM
AbaZ's Avatar
The quality of the valve is very nice, I am using one on my daily driver at the momment, it will be going back on the race car. It doesnt sound like other blow off valves, since its vented all around the body of the valve. It kinda sounds like a Whipish.. sound.. also if you are going to be running a Non-vtec engine with large cams, you will need to get a differnt spring inside the valve, so it opens.
If you want something that gets peoples attention.. Go with a HKS SSQV or a Blitz valve, they are very loud and annoying.
Jeff frank
Old Sep 24, 2002 | 04:26 PM
minivan81's Avatar
Default Re: Tial BOV (AbaZ)
nice info i jumped on the groupbuy right away, Tial has good stuff
Old Sep 24, 2002 | 04:48 PM
rjardy's Avatar
Jeff frank
why would it not open with non vtec? i understand the large cam (no vacuum) but why would it not open without vtec. Vacuum is vacuum and it should open as long as it gets its vacuum signal. RIGHT?
Rob
Old Sep 24, 2002 | 04:56 PM
AbaZ's Avatar
Rob
Ya know, I guess it wouldnt matter if it was Vtec or Not, as long as you had big *** cams. blah dont listin to me.. haha
JEff
Old Sep 24, 2002 | 04:58 PM
rjardy's Avatar
HAA okay, you had me confused thanks for clearing it up. I was pretty sure i was right, anyhow, everyine pretty much agrees that the quality is top notch and this is the BOV to have? i think im going to go with it, just one more question. Is it audible at all? i mean can you hear it under normal driving conditions?
Rob
Old Sep 24, 2002 | 05:03 PM
AbaZ's Avatar
Can you hear it?.. Sure it makes noise I guess, just doesnt sound like the conventional Blow off valves.. Mine has a 20in vacuum spring installed, I was having a tough time getting the ****** to open with my Built ZC and Crower Cams.. Still could here compressor surge.
Jeff
Old Sep 24, 2002 | 05:04 PM
rjardy's Avatar
what spring do they come with?
Rob
Old Sep 24, 2002 | 05:39 PM
Rain_man's Avatar
New User
Straight from a email TiAL sent me:
The BOV works on a combination of boost under the valve and vacuum on the diaphragm. 2 settings are available 9psi and 11psi Example would 6psi(12in) vacuum + 5psi under the valve= 11psi spring setting.
Old Sep 24, 2002 | 05:55 PM
rjardy's Avatar
okay but how do i know whats god for my setup? ~8 psi ? im lost
Rob
