Which motor is better for turbo?
Old Sep 24, 2002 | 04:58 AM
BoostedD15B7's Avatar
Default Which motor is better for turbo?
WHich is better for a turbo? A B20 or LS motor? I can get a b20 longblock complete for $750. Im assuming this is cheaper then the LS longblocks. How do they compare in compression, hp, handling boost? The b20 will bolt into a 94 del sol right?
Old Sep 24, 2002 | 06:25 AM
TheIntegraGuy's Avatar
Default Re: Which motor is better for turbo? (BoostedD15B7)
I'm not sure about the specs, but I know for a fact, that B20 is a bit stronger. Make sure to get a B20Z though. If you dont get the Z, you're stuck with a ***** B20 without *****. Stock B20Z's come with 146 Hp where LS's come to 140 I believe. There are many fine points about both motors and both would be a great choice. it's up to you.
Yes...All B-Series will bolt up to your sol.
Old Sep 24, 2002 | 06:59 AM
Ri5e's Avatar
Default Re: Which motor is better for turbo? (SiDESLiDE240)
Get a LS motor and resleeve it via Golden Eagle. I learned the hard way....
Old Sep 24, 2002 | 07:13 AM
4dGSR at work's Avatar
Default Re: Which motor is better for turbo? (4 Stroke)
built b20 is my choice
Old Sep 24, 2002 | 07:18 AM
ekb18c's Avatar
Default Re: Which motor is better for turbo? (4dGSR at work)
b20 at even 5psi is awesome!!
Old Sep 24, 2002 | 07:20 AM
SiRkid's Avatar
Default Re: Which motor is better for turbo? (ekb18c)
ls.. i think the b20 w/turbo is TOO much torque for front wheel drive(on the street)
Old Sep 24, 2002 | 08:28 AM
93LSivic's Avatar
Default Re: Which motor is better for turbo? (SiRkid)
Either.................................... with Darton sleeves
Old Sep 24, 2002 | 08:36 AM
TheSwift1's Avatar
I agree. LS motor is easier to fid and usually cheaper...same exct crank..juste an LS and resleeve it to 84.5mm..now u have a built B20! with about the same amount of money...
Old Sep 24, 2002 | 03:06 PM
Default Re: Which motor is better for turbo? (TheSwift1)
will both bolt into the civic/delsol mounts? how about wiring?
ALLMOTA92EG
Feb 6, 2005 11:28 PM
CivicHb04
Feb 16, 2004 01:05 AM
DriveSideWays
26
Dec 16, 2003 09:40 AM
who00knows
Feb 20, 2003 02:18 PM
ZensokuEK
Feb 18, 2003 04:54 AM
