b18b or b16a2 turbo......
Old Sep 22, 2002 | 01:47 PM
EM1specR's Avatar
Default b18b or b16a2 turbo......
im debating swapping in a b18b or b16a2 into my civic.
now i want to purchase the greddy kit for this new engine, in order to keep it street legal
the b18b will give me torque until the turbo spools up
but the b16a2 will pull harder up top
oh and i plan on using stock internals
what are your guys opinions?
Old Sep 22, 2002 | 02:17 PM
ATgrills.com's Avatar
Default Re: b18b or b16a2 turbo...... (EJ8specR)
If you go stock internals. I would say the b18, get a thicker head gasket and you can boost about 12-12psi safely and you have to keep on mind, the motor will be much cheaper!
Tyler
Old Sep 22, 2002 | 03:02 PM
94civicx's Avatar
New User
Default Re: b18b or b16a2 turbo...... (ATgrills.com)
go with the b18b as you can run a high psi on your stock internals compared to the b16a2
Old Sep 22, 2002 | 03:28 PM
SiRkid's Avatar
Default Re: b18b or b16a2 turbo...... (94civicx)
yeah he can run higher psi..so what....a 10 psi b16 will be faster than a 12 psi b18b!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
you guys really need to do some research
Old Sep 22, 2002 | 07:11 PM
fire7882's Avatar
Default Re: b18b or b16a2 turbo...... (SiRkid)
i agree with sirkid. the b18b will need more boost to get the hp of the b16 on less boost. i would even say that the b16 on 8 psi would be faster than the b18b on 11 or 12 considering everything else stock. you can also put a thicker head gasket on the b16 and push 10 psi well within the safe limits.
[Modified by fire7882, 11:12 PM 9/22/2002]
Old Sep 22, 2002 | 07:38 PM
The_Head's Avatar
How 'bout a B16A bottom end with a B18B head? Cheapest of both worlds!
Naw, just kidding. I vote for the B18B, better low end torque, a better street motor IMO.
Old Sep 22, 2002 | 08:23 PM
SiRkid's Avatar
Default Re: b18b or b16a2 turbo...... (xThexHeadx)
its all prefrence!
b16 isnt that bad for street as people make it out to be.
do some research... and make you own choice!
Old Sep 22, 2002 | 08:26 PM
The_Head's Avatar
true, the B16A makes up for it's dearth of low-end power a little with it's shorter gearing ratios.
But I think the dude wanted our opinions on the matter, not a "make your own choice" response. I don't think that helps him a whole lot.
pokmijn
Aug 9, 2008 06:44 AM
ej1civic
May 16, 2003 12:36 AM
mz3bo
Jan 13, 2003 02:52 PM
H22CIVIC
Oct 22, 2001 04:10 AM
