map sensor
Old Sep 22, 2002 | 09:31 PM
forced-d16's Avatar
Default map sensor
i have a missing link and my map sensor keeps throwing a code.
i have a v-afc aslo, i heard that there is a v-afc trick for the map sensor
Old Sep 22, 2002 | 11:46 PM
inspyral's Avatar
Default Re: map sensor (forced-d16)
Do you have the AFC set to add fuel anywhere? If so, is it above +10-12%? If the answer is yes, the additional 10-12% voltage that the AFC adds to the MAP is enough to trigger a MAP code. This will happen even if you have a Missing Link, since the AFC is adding to the MAP signal electronically, where as the Missing Link manipulates the amount of pressure the MAP sees physically.
Carbcivic
Mar 14, 2007 05:55 AM
dominate9
Nov 15, 2003 01:01 PM
Turbo EG6
Aug 19, 2001 05:04 PM
