#1 Cylinder rings are toast, honing ?
Guest
Posts: n/a
Ok I've got 90-190-185-188 compression. It puts out blue smoke under acceleration, no other time. I assume it's the #1 rings or lands. My question is: Can I just hone the #1 cylinder and replace the rings and/or piston, or do I have to do all four. And also, I'm just going to hone not bore, it's a relatively new engine (40K) How many turns, up down strokes, of the hone so I don't take too much off?
One more question if I buy some low mileage used pistons that come with rings can I reuse them. Keep in mind this is a beater not a racer.
[Modified by filetofit, 12:14 AM 9/25/2002]
Re: #1 Cylinder rings are toast, honing ? (b18c5turbo)
yeah, change all your rings....and repalce the toasted piston..
when honing do 12 QUICK passes up and down up to the edge of the cylinder wall....you should get a descent cross hatch then...
stan
stan
