Greddy 60mm EGT... Where to put it?
OK I bored out my autometer dual pod. the gauge's diameter fits the pod, but the body of the gauge only goes half way in because it hits against my pillar . Anyone have a 60mm greddy egt mounted in the autometer dual pod? I searched but didn't find a good answer on what i should do about it. my only other plan would be to buy back a dual pod and put back the autometer a/f and boost in the dual pillar pod and then buy a mounting band and mount he EGT somewhere else
Re: Greddy 60mm EGT... Where to put it? (CivicRyda2k)
I'm in the same boat, I'm thinking of using the glove box but its so inaccessible for the most part it kinda defeats the purpose. I bet it would fit nicely in the cruise control **** or the dash dim control area... c'mon how often do you use those anyways Good luck!
Re: Greddy 60mm EGT... Where to put it? (inspyral)
You have to cut a chunk out of your pillar for them to fit on the dual pod........I have my Greddy 60mm boost and Greddy 60mm EGT there.
I have my Greddy 60mm oil pressure and Greddy 60mm fuel pressure where my cruise and dimmer switches used to be located................took em out and dremeled the **** out of each hole.......they look like stock gauges and the there is plenty of room behind each............forget that bezel crap!!!
This is in a 95' GSR.....send me an email and I will send you pics.....Farnsrocket@cs.com
[Modified by Farnsrocket, 4:25 AM 9/25/2002]
New User
Do the Greddy gauges come with that hanging holder thing?? I have some autometers and I think that is a pretty rad place to put them...I was going to just go pod, but if I can figure that out like yours, I'll just hang em..
do you know how much longer the 60mm is compared to the 52mm? My 52mm was like LLLOOONNGGG and i thought it wasnt going to fit..but it fits nicely at the bottom of my 3pod. If i remember ill pull out the gauge tomorrow and messure it for ya. (maybe you should bug me?)
liam
liam
2000__GSR
08-22-2005 10:20 PM
jaymes2030
10-17-2003 06:36 AM
TurboR1391
11-24-2002 08:36 AM
Rob03Pro5
11-19-2001 08:18 AM
