detonating
Old Sep 24, 2002 | 05:21 AM
turbofed EX's Avatar
Default detonating
i'm running 9psi and at about 5800 rpms in every gear except for first, i hear the engine start to detonate. fuel setup is this 255lph pump and regulator set to 60psi, could it be to rich? Should i try to gap my plugs colder? or can i put in a set of prelude injectors? this is all on a sohc vtec
Old Sep 25, 2002 | 08:19 AM
Default Re: detonating (turbofed EX)
need help cant figure it out
Old Sep 25, 2002 | 08:21 AM
tegtyper's Avatar
Youre not too rich. Pull out some timing
Old Sep 25, 2002 | 08:42 AM
93TurboSi's Avatar
sounds like you need a better fuel setup. is your fuel pressure regulator boost dependent or do you have it just static set to 60 psi. If you have it just static set you might want to think about getting a vortech fmu 8:1 should be good.
Old Sep 25, 2002 | 09:11 AM
VTC_CiViC's Avatar
So.. 255lph pump, stock injectors, no FMU and you're trying to boost? I think thats a good reason why you're detonating. You need to supply fuel for boost which you aren't doing.
Old Sep 25, 2002 | 09:13 AM
Default Re: detonating (93TurboSi)
i have the vortech also, and the 60psi is static on the rail.
pull out timing, already have it set to 8, cause stock is 12 +- 2
Old Sep 25, 2002 | 10:46 AM
chirish's Avatar
Listen to VTC_slow -
If that turns out not to be your problem, check your compression and make sure everything is within the proper specs. You may have lots of carbon build up, causing hot spots which invite pre-ignition to occur.
Old Sep 25, 2002 | 11:45 AM
Drew Peacock's Avatar
Default Re: detonating (PssshhhMr2)
Yeah you will need bigger injectors he's running 9psi on stocks!! They will be maxing out to much pressue from the fmu and regulator. If you want the motor to last turn down the boost, untill you get it tuned properly. 7psi max for the moment. And do you have one stage colder plugs ??? You need them!! gap to .32..
[Modified by turbozxi, 8:46 PM 9/25/2002]
Old Sep 25, 2002 | 12:18 PM
Default Re: detonating (turbozxi)
can i buy plugs gapped a .32 or should buy new plugs and gap them myself
Old Sep 25, 2002 | 01:24 PM
rjardy's Avatar
Are you running any type of fuel management? FMU? afc hack? anything?
Rob
Old Sep 25, 2002 | 01:38 PM
Default Re: detonating (rjardy)
vortech fmu, adj. fpr, 255 lph pump
Old Sep 25, 2002 | 02:15 PM
rjardy's Avatar
12:1 fmu? im hoing that you have an INLINE pump. Am I correct in assuming that?
If not, that is why you are leaning out, an intank CANNOT supply the fuel needed to properly operate the FMU.
Rob
Old Sep 25, 2002 | 02:56 PM
Cramerox's Avatar
Rob
FMU needs inline Sir
Old Sep 25, 2002 | 03:00 PM
rjardy's Avatar
Default Re: detonating (Cramerox)
I KNOW THAT. did you read my post? i said that it takes an inline to properly operate an FMU!!!!!!!!! INTANK will not provide enough pressure
Rob
Old Sep 25, 2002 | 03:54 PM
in tank i guess i should try a inline?
Old Sep 25, 2002 | 04:11 PM
just checked the FMU to find its rate and cant find it the # on the underside of it is
6Z110-130
Old Sep 25, 2002 | 04:41 PM
Cramerox's Avatar
Rob i believe u miss uderstood me.....i was actually agreeing with you. "Sir" was referring to the person who created the post
Old Sep 26, 2002 | 12:57 PM
just checked my timing at idle and it is 8 initial timing, sound okay? to low i think
Old Sep 26, 2002 | 01:05 PM
rjardy's Avatar
oh MY BAD
Rob
Old Sep 26, 2002 | 06:28 PM
Gap em yourself do you have 1 stage colder plugs??????? The reason your detonating is because fmu's are not designed for 9psi of boost with standard injectors
gtowni3
Mar 17, 2004 07:59 PM
J337_UNIT
Jan 21, 2004 06:52 PM
2k1civicturbo
Jan 23, 2003 10:43 AM
KLN
Jun 3, 2002 11:02 AM
fast[R]
Apr 27, 2002 06:09 AM
