2-step on a stock ignition?
Old Sep 24, 2002 | 05:41 AM
bigTom's Avatar
Default 2-step on a stock ignition?
does anyone know how to wire up a 2 step on a stock honda ignition?
Old Sep 26, 2002 | 12:16 AM
bigTom's Avatar
Default Re: 2-step on a stock ignition? (ek9t)
Old Sep 26, 2002 | 01:32 AM
Arturbo's Avatar
Better than steak
25 Year Member
Nope.
Old Sep 26, 2002 | 01:37 AM
simple4012's Avatar
New User
Hondata biotch
Old Sep 26, 2002 | 09:42 AM
bigTom's Avatar
Default Re: 2-step on a stock ignition? (simple4012)
Hondata biotch
its for a stock motor!
last time up
Old Sep 26, 2002 | 09:47 AM
VaporTrail's Avatar
New User
all it does is interupt ground to the coil when a certain rpm is reached
Old Sep 26, 2002 | 10:01 AM
bigTom's Avatar
Default Re: 2-step on a stock ignition? (VaporTrail)
so im guessing i can put it in line directly to the coil ground?
Old Sep 26, 2002 | 10:03 AM
DSF's Avatar
DSF
Sure. Get MSD's soft touch rev limit module for stock ignitions. Then get MSD's 2 or even 3 step module. Done.
[Modified by DSF, 2:19 PM 9/26/2002]
Old Sep 26, 2002 | 10:26 AM
DSF's Avatar
DSF
Default Re: 2-step on a stock ignition? (Matthew)
I've always thought about this.....
MSD makes a RPM switch, and you could have it wired in to cut spark at the desired rpm. In order ot make it not cut spark at the rpm while racing, you could wire the switch itself into the clutch, just like the sensor that makes sure you clutch is down in order to start your car? This would be an old fashion clutch cut, and would allow full throttle shifting as well.
I'll check out the MSD box, that sounds rad.
Only problem there is you'll get some serious fuel puddling. MSD's soft touch drops every other spark event as to prevent this. Imagine what would happen if you followed through with your idea and then released the clutch... lot's of fuel + sudden spark = innovative thinking though
Old Sep 26, 2002 | 06:09 PM
SIK IN DA HED's Avatar
New User
Default Re: 2-step on a stock ignition? (DSF)
i wouldnt recommend it. do it the right way and get a digital 6+, sport compact+, or a 6al to go with the module.
Old Sep 26, 2002 | 06:12 PM
DSF's Avatar
DSF
Default Re: 2-step on a stock ignition? (dlplayboy)
I agree. It's actually not much more for the 6AL and that has the soft touch rev limit built in. That's what I run.
LSVTEC 91 Civic
Oct 10, 2004 05:30 PM
boosted_dc2
Aug 21, 2004 12:26 PM
DubyaAye
Apr 27, 2004 03:35 PM
r2fst4u
Jun 23, 2002 05:43 PM
