irregular idle problems
Old Sep 24, 2002 | 04:28 PM
avividmemory's Avatar
Default irregular idle problems
since the turbo install my car has been idling really low about 500 rpms...today it stalled a couple times because of the irregular idle...what could the problem be? first guess was to change the plugs and wires so i ordered some new range 7's today...
any other ideas?
Old Sep 24, 2002 | 04:40 PM
sleepercivic's Avatar
Default Re: irregular idle problems (SpoolinLS)
idle air screw make it idle higher, because you have a turbine to push now with your exhaust
TERRY
98civicEX's Avatar
could also be your vacuum lines...check'm all.
Old Sep 24, 2002 | 04:45 PM
Default Re: irregular idle problems (98civicEX)
for a noob...how do you check the idle air screw? and what do you check the vacuum lines with? or how do you fix one...
Old Sep 24, 2002 | 06:28 PM
turbod16y8's Avatar
is your o2 sensor hooked up?
Old Sep 24, 2002 | 06:30 PM
Default Re: irregular idle problems (turbod16y8)
sure is...it wasnt for a while...but is now...still no change
Old Sep 24, 2002 | 06:45 PM
98civicEX's Avatar
you check your vaccum lines by making sure everything is connected, and also look for tears. you can also get a vaccum tester. they have them any auto parts place (autozone, discount auto, napa) it just makes sure all your lines hold vaccum.
Old Sep 24, 2002 | 08:11 PM
thanks i wasnt sure if they had something at a local autozone...this could explain why im running so rich...if the vacuum is messed up...it would alter the fmu setting when it releases more gas...ah yes, someday it will all work in harmony
Old Sep 24, 2002 | 08:29 PM
CzanSOHC's Avatar
if you have a vacuum leak, you idle is going to move up and down from 500 to like 1500 over and over...so i don't think that is the problem.
Try and mess w/ your throttle cable and adjust that, then adjus tthe idle contol screw on the throttle body.
weaslehunter1
Jan 26, 2015 03:49 PM
ILoveJDM.
Dec 25, 2005 11:34 AM
UNKNOWN_MEMBER
Aug 11, 2005 08:55 PM
ITSTOCK
Oct 28, 2004 12:03 PM
