b-series junkyard setup
Old Sep 23, 2002 | 06:48 PM
JCushing's Avatar
Default b-series junkyard setup
ok i just got done with my b20 swap and i happened to notice that my unused b20 exhaust mani looked similar to the hf mani used in d-series getto/junkyard turbo setups... if i had to guess i would say its maybe 4 inches or so lower than the hf mani so basically im pondering if this would be feasible or not... i placed the mani on my freinds car which was being worked on at the time and it seemed that it would make the turbo hang pretty low but no lower than the tow hooks.. probably more along the lines of the oil pan height..
tell me what you think.............
[Modified by JCushing, 10:50 PM 9/23/2002]
Old Sep 23, 2002 | 06:52 PM
Brad's Avatar
Default Re: b-series junkyard setup (JCushing)
if it's too low you will have problems with the gravity fed oil return line.
Brad
Old Sep 23, 2002 | 07:02 PM
TurboInteg95's Avatar
B series turbo manifolds are getting cheap these days. I wouldnt hassle with the stock manifold.
Old Sep 23, 2002 | 07:26 PM
rjardy's Avatar
Default Re: b-series junkyard setup (TurboInteg95)
REALLY!! some one was having a GB on a mani for like 120 i beleive, allmost anyine can afford to turbo nowadays
Rob
Old Sep 23, 2002 | 08:57 PM
TURBOSALES's Avatar
Default Re: b-series junkyard setup (rjardy)
i agree to an extent, but you still gotta remember that you get what you pay for.
quality doesnt come cheap.
Old Sep 24, 2002 | 12:55 AM
ion_four's Avatar
Default Re: b-series junkyard setup (TURBOSALES)
that b20 manny has a 3bolt flange. good luck finding a turbo that will fit that (with adaptation) it'll probably also sit too low. you could buy a manny for a B or even D-series (and redrill the mounting holes) and you'll be better off. manifolds are not friendly to dick with, though...cast iron is expensive to get welded.
Old Sep 24, 2002 | 02:20 AM
JCushing's Avatar
Default Re: b-series junkyard setup (ion_four)
it was just a thought... hehe
yeah i know id be better off buying one but i just figured i would put it up here cause it looked possible and ive never heard it before
turbo24
May 2, 2010 12:41 PM
Mr.Quang
Mid-Atlantic (Sales)
Feb 11, 2008 03:17 PM
Mugen112
May 6, 2006 02:49 PM
unknown0001
Mar 18, 2005 07:12 AM
