Overheat problem.....WON'T GO AWAY.... Help
Old Oct 27, 2002 | 12:52 PM
NXAccordTO4B's Avatar
Default Overheat problem.....WON'T GO AWAY.... Help
OK, guys maybe someone can help me. Ill out of answers. My turbo f22 keeps overheating. Ive change the headgasket 3 times. Change the themostat, and checked everything. The car runs fine when im not boosting. But when i boost past 6psi, my car losts alot of water out of the overfill bottle next to the radiator. Any suggesstion? I already took the head off and got it resurfaced and leak and pressure checked it. Change the headgasket 3 times already. and the water pumps fine. Any suggestion WOULD BE THANKFUL....... IM tired of taking the stupid head off and on. thanks
Old Oct 27, 2002 | 01:07 PM
DRAGLS's Avatar
Default Re: Overheat problem.....WON'T GO AWAY.... Help (NXAccordTO4B)
Did u check the sleeves might have a crack in one of them...
Happened to me, I thought it was the head gasket also and it only do it when i would boost...
Old Oct 27, 2002 | 01:17 PM
Default Re: Overheat problem.....WON'T GO AWAY.... Help (DRAGLS)
The last time i took the head off. I look at the sleeves but didn't notice any cracks in them
Old Oct 27, 2002 | 01:21 PM
DRAGLS's Avatar
I didn't either ended up pulling the block pulling the guts out and it was a hairline fracture straight thru one could hardly see it...
Old Oct 27, 2002 | 01:34 PM
wow.....that had to suck. owell i guess i could check that as a last resort. thanks for the info
Old Oct 27, 2002 | 03:24 PM
dantamparacer
Mar 31, 2010 04:03 PM
shady1375
Oct 19, 2009 05:47 AM
aho
Dec 15, 2007 09:24 PM
redsikiller
Nov 11, 2005 09:46 PM
VTgringo
Nov 29, 2003 11:40 AM
