My first problem...car wont hold vacuum, joygasm
b18c1
Ok....After pushing my car a little bit last night...it will not idle now.
Upon inspection, I noticed that my knock sensor wire harness came off the actual knock sensor (wtf)
I pulled the spark plugs, and noticed that the 4th cylinder plug had the prong chipped or melted off...I replaced the spark plug and knock sensor ****...and started the car and it still ran like it was previously.
I took off the spark plug wire for the 4th cylinder, started the car and it was no different that if it had all four wires. I didnt get a chance to do a compression test...I had to catch a bus back to school.
Any suggestions? Would a compression test tell me anything other than the fact Im losing compression? In other words...would it tell me anything important before I start to take the motor apart...
Thanks in advance
[Modified by B18EG6, 9:21 PM 10/27/2002]
Thanks in advance
Re: My first problem...car wont hold vacuum, joygasm (B18EG6)
If a spark plug wire was defective...or fucked up distributor, would i still hold vacuum even though the cylinder was not getting any spark?
Could this be a simple ignition problem?
Re: My first problem...car wont hold vacuum, joygasm (GraphiteAccord)
yeh I thought so too...bent a valve or cracked a piston ring...i dunno...Im not at my car, I wish I was though...
if it was a bent valve or soemthin like that wouldnt it still get spark from the distributor tho? which i dont think it was
Re: My first problem...car wont hold vacuum, joygasm (Turbo E)
sounds like BAD detonation.
I would say that the number four piston are gone.
spark plug prong melted = sever detonation
[Modified by dwilson, 8:38 PM 10/28/2002]
ss85510
11
10-02-2010 09:42 AM
