Another Newbie Wanting Turbo info!!
Old Oct 27, 2002 | 01:07 AM
Arch-Angel's Avatar
Default Another Newbie Wanting Turbo info!!
If I lower the compression ratio on a H23 to allow me to run 10-12 psi safely, won't I lose a lot of acceleration in the bottom end? If so, is there any way of getting that off the line acceleration back?
Would it help to get a lightened flywheel?
Or should I just stay with stock internals and run lower boost?
faster 0-60mph is what I am after
Old Oct 27, 2002 | 07:59 AM
BoostedH23a1's Avatar
Default Re: Another Newbie Wanting Turbo info!! (Arch-Angel)
flywheel helps spoolage alot. but if u get to light u willnt have traction. get a 3 inch dp and a 3 inch exhaust that will help spool. runing 10 psi on 8:5:1 is kinda like running 8 psi on 10:0:1. (there is actually a formula but i dont know it)..if u are looking for 0-60 with a turbo i would get someting small. like a TD05 or someting.
Old Oct 27, 2002 | 04:57 PM
Arch-Angel's Avatar
Default Re: Another Newbie Wanting Turbo info!! (BoostedH23a1)
there's food for thought
I was actually looking at a t3 or something, all the mechanics near me says I would best go with something big cause the engine is a 2.3L. That was cool with me, but I figured the lag would kill my acceleration.
Old Oct 27, 2002 | 04:59 PM
rjr162's Avatar
a t3/4 will work perfect for honda 4 bangers.
Old Oct 27, 2002 | 05:19 PM
Arch-Angel's Avatar
Default Re: Another Newbie Wanting Turbo info!! (rjr162)
what computer do you think would be best? Not really keen on piggybacks, maybe a PowerFC?
Old Oct 27, 2002 | 06:56 PM
sutrusu's Avatar
depends if you know someone to tune it.
if you have enough loot for powerfc, you might as well get AEM and get someone to tune it. at least you wont be converting all the metric measurements with the AEM like you would be doing with the pfc
b18_ef_hatch
May 20, 2014 09:07 PM
kreatekustomz
Aug 8, 2009 10:27 AM
james9761217
Aug 14, 2006 04:23 PM
wade
Sep 15, 2004 03:20 PM
