turbo sohc, fuel problem
Old Oct 28, 2002 | 11:40 AM
TypRice's Avatar
Default turbo sohc, fuel problem
i have a 1990 civic dx with a 1995 civic ex motor in it , im using the greedy turbo kit(used). i have stock injecters, stock 1990 dx fuel pump. when im running 5 lbs. of boost im fine. i lean out at 12lbs. of boost at 4700 rpm in every gear? what should i do? help.
Old Oct 28, 2002 | 11:46 AM
inspyral's Avatar
Default Re: turbo sohc, fuel problem (TypRice)
Are you running a 12:1 FMU? Inline pump? I hope you have both if you're trying to run 12lbs of boost on stock injectors.
Hammett's Avatar
Get bigger injectors, bigger fuel pump and run afc hack. or smc..
Old Oct 28, 2002 | 11:51 AM
B20T's Avatar
12psi none built.... KABOOM is what you will here!!!!!!!!
Old Oct 28, 2002 | 11:58 AM
TypRice's Avatar
i have a vortec FMU, greedy block box
Old Oct 28, 2002 | 11:59 AM
TypRice's Avatar
Default Re: turbo sohc, fuel problem (inspyral)
what size injectors come with the greedy kit (sohc)
Old Oct 28, 2002 | 12:10 PM
CzanSOHC's Avatar
it doesn't come w/ injectors. You need to get a inline fuel pump w/ that 12:1 FMU, that should work. Ditch the blue box, and 12psi w/ stock injectors....just dumb.
Hammett's Avatar
My kit did not come with injectors.
94hybridcoupe
Apr 6, 2005 06:53 AM
gtowni3
Mar 17, 2004 07:59 PM
BorderM3
Sep 5, 2002 11:58 AM
KevronsEG
Aug 5, 2002 08:29 PM
