0.48 or 0.63 a/r housing for b18b
Old 10-27-2002, 05:27 PM
Pat
Pat's Avatar
Default 0.48 or 0.63 a/r housing for b18b
Does anyone have experience with either spec? Is the 0.63 gonna spool much later and is the 0.48 that limiting on higher boost if I only want to run abou 6-8 psi? TIA
Old 10-27-2002, 05:31 PM
sutrusu's Avatar
Default Re: 0.48 or 0.63 a/r housing for b18b (Pat)
get the .63. you'll be much happier.
Old 10-27-2002, 08:28 PM
pissedoffsol's Avatar
if you only want to run 6-8psi, get the .48. thats plenty big to make that boost... and will give less lag than the .63.... although, if you ever want to run more boost down the line- you really should get the 63.
perhaps a compromise, and get a .57 trim
Old 10-27-2002, 08:32 PM
New User
01geeser's Avatar
Default Re: 0.48 or 0.63 a/r housing for b18b (sutrusu)
Old 10-27-2002, 08:36 PM
B*A*N*N*E*D
PeakBoost's Avatar
Default Re: 0.48 or 0.63 a/r housing for b18b (01geeser)
if you are only looking to run 6-10 lbs of boost, you'll be happy with the boost response of the .48
and when your looking to run more boost, you can always just buy the .63 a/r turbine housing for only $159
just my 2cents..
Old 10-27-2002, 09:14 PM
shadowdawn's Avatar
Default Re: 0.48 or 0.63 a/r housing for b18b (CHEAPTURBOdotCOM)
Isen't it true though that the top end will suffer a bit no matter the boost level with a smaller turbing housing like that?
Old 10-27-2002, 09:53 PM
redline201's Avatar
i was wondering the same thing for my b16a
Old 10-28-2002, 05:28 AM
craesq's Avatar
I run a .63 turbine on my B18B at 9psi and have full boost at 3700 in 1st gear. It is less in other gears because of the load on the engine. Full boost at 3000 in 4th gear.
- Chris
Old 11-27-2002, 11:01 PM
redline201's Avatar
Default Re: 0.48 or 0.63 a/r housing for b18b (craesq)
ttt
Old 11-28-2002, 12:53 AM
juicy.koreans.suck's Avatar
Default Re: 0.48 or 0.63 a/r housing for b18b (redline201)
just my 2cents..
Old 11-28-2002, 01:03 AM
Pat
Pat's Avatar
Default Re: 0.48 or 0.63 a/r housing for b18b (juicy.koreans.suck)
sweet! back from the dead. I did end up going with the .48 since I didn't plan to boost higher than 8 psi for the moment
Old 11-28-2002, 06:50 AM
legendboy's Avatar
hmm.......I shift at 5500rpm with my .42 I just bought a T4 tho so ....
Old 11-28-2002, 11:02 AM
zojirushi's Avatar
Default Re: 0.48 or 0.63 a/r housing for b18b (legendboy)
how about an automatic integra? .48 or .63? My car shifts around 7k rpms.
rollagti
10-22-2006 06:03 AM
LSVtechnologytur...
11-18-2004 11:22 AM
1990hondaHF
08-05-2003 11:54 AM
Quick Reply: 0.48 or 0.63 a/r housing for b18b
