... car problems... please help... !!!
Old Oct 27, 2002 | 08:31 PM
1.8T_EG's Avatar
Default ... car problems... please help... !!!
... just did a compression test... here are my numbers
1 : 180
2 : 178
3 : 185
4 : 185
... great numbers, right?... ((makes me feel a little better))... but now i am totally confused about what my problem is... wtf?!?!?... so now what?... like i said before :
problems :
- burns oil (needs about 1/2 a quart a week)
- burns coolant (need to refill overflow reservoir every 1-2 weeks) (can sometimes smell in car)
- white smoke from exhaust (sometimes, but not always, but esp. at wot)
- blue smoke from exhaust (sometimes, but not always)
- light smoke from under the hood (sometimes)
- sometimes hard to keep idle without stalling (stopped happening after going to the darkside)
- lower than expected performance (191whp/165tq, see sig for setup) (i was expecting 220-250whp)
... i have been told that i could be a couple of things... like a cracked headgasket (not blown or i would be overheating right away)... or worn o-ring... or worn valves or cracked ring lands (what are these and how can i check if this is the problem? pull the head, right?)... or cracked sleeves...
... thanks for taking the time to read... any help is really appreciated... thanks...
Old Oct 27, 2002 | 08:50 PM
B18EG6's Avatar
Default Re: ... car problems... please help... !!! (1.8T_EG)
yes...please share knowledge
[Modified by B18EG6, 12:50 AM 10/28/2002]
Old Oct 27, 2002 | 08:51 PM
Drew Peacock's Avatar
Is your turbo oil and water cooled? Perhaps the seals on your turbo are gone!!!
Old Oct 28, 2002 | 01:52 AM
rjardy's Avatar
Default Re: ... car problems... please help... !!! (turbozxi)
You need to perform a leak down test to make sure that your rings are not damaged. You can make those numbers and still have bad rings, think about it, if the piston is floping up and down and keeps putting the pressure back in the cylinder, there is no way you can tell if the pressure will slowely bleed off. So preform a leakdown check and make sure that your pressure stays constant.
HTH
ROB
Old Oct 28, 2002 | 05:52 AM
1.8T_EG's Avatar
^_^
Old Oct 28, 2002 | 09:27 AM
1.8T_EG's Avatar
so a leakdown test huh?... anyone else?...
Old Oct 28, 2002 | 11:36 AM
Muckman's Avatar
Moderator in Chief
Default Re: ... car problems... please help... !!! (rjardy)
How do you do a leakdown test
Old Oct 28, 2002 | 11:39 AM
1.8T_EG's Avatar
Default Re: ... car problems... please help... !!! (Muckman)
http://www.geocities.com/dsmgrrrl/FAQs/leakdown.htm
Old Oct 28, 2002 | 08:06 PM
1.8T_EG's Avatar
1 : 180
2 : 178
3 : 185
4 : 185
problems :
... up for the insomniacs
bpfergu
Mar 5, 2012 05:27 PM
boostedeghatch
Jul 5, 2006 03:34 PM
TekSI
Oct 12, 2005 05:14 PM
1.8T_EG
Nov 6, 2002 06:44 PM
1.8T_EG
Oct 26, 2002 10:50 PM
