BottoM END, boost!!!
Old Oct 24, 2002 | 08:55 PM
swpdb16's Avatar
Default BottoM END, boost!!!
I am considering building my engine in preperation to the turbo i will be getting this winter. I bought the eagle rods today and i will be getting the arias pistons next week. I dont know what to upgrade after that, (Oil pump, sleeves or what) Anything that you can think of will be taken into consideration, I am also wondering how much boost just the rods and pistons will be able to handle ThankS
Old Oct 24, 2002 | 09:15 PM
skilzz's Avatar
Default Re: BottoM END, boost!!! (swpdb16)
what kinda block is this? Also how much HP or psi are you looking to run?
Old Oct 25, 2002 | 07:48 AM
swpdb16's Avatar
Its a stock b16 block, i am looking to run around 12-18 lbs of boost or too at least get me into the 12 second range
Old Dec 9, 2002 | 07:58 PM
redline201's Avatar
ttt
Old Dec 9, 2002 | 08:05 PM
98civicEX's Avatar
compression of pistons??...eagle rods can easily handle 400+ horses, if looking to run more then 12+psi, it's recommended to get the block re-sleeved, GE or Darton are very popular and known to take what you throw at them. stock water and oil pump will work, and do some research on head gaskets if you decide to get the block resleeved.
Dugdude
Aug 25, 2013 11:43 PM
collinsvc15
May 28, 2011 08:27 AM
B16afmaxt
Nov 11, 2009 04:27 PM
chinners10
Apr 8, 2003 12:50 AM
aut0tek
Apr 2, 2003 02:50 AM
