What the hell!!!
Old Oct 26, 2002 | 07:22 AM
deacs's Avatar
Default What the hell!!!
Right this is doing my head in: heres my set up
D16Z6
T3 turbo
2.5 inch full system
450cc DSM injectors with resistor box
MR2 200lph in tank
BOV
Starion FMIC
running the AFC hack with settings at -35% across the board apart from at 1000rpm where its at -30%
BKR7E plugs
timing retarded 4 degrees from stock
My problem is im getting detonation at anythything over 7 psi, im in the uk and running on 98 octane fuel, why the hell im i getting detonation?? u guys in the us run 10psi and **** on crappy 92 octane etc, what the hell can be wrong??? I have no boost leaks as this has been checked, arghhh its driving me mad i want 9psi daily but at WOT im just getting pinking, not real bad but surely it shouldnt be happening, specially as its cooler over here and cos of the 98 octane gas.
standard compression ratio on a UK spec D16Z6 is 9.2:1 is this the same as over there?? would going a another step colder on the plugs help as our standard plugs in the UK are 6's??
Please help im on the verge of going back NA!!
Old Oct 26, 2002 | 07:54 AM
AB16A2T's Avatar
Default Re: What the hell!!! (deacs)
It is all in the tuning. Tuning is key!
Old Oct 26, 2002 | 07:55 AM
deacs's Avatar
Default Re: What the hell!!! (AresB18BTurbo)
U dont say!!
Old Oct 26, 2002 | 08:03 AM
Vanilla Ic3's Avatar
How many miles are on the engine? You could have carbon build up on your pistons. Have you tried richening it up with the afc? Did that stop the pinging? nO? Did you try retarding the timing a degree or two more? did that help? no? Maybe buy one of those msd btmz or something?
Old Oct 26, 2002 | 08:06 AM
deacs's Avatar
Default Re: What the hell!!! (Vanilla Ic3)
85,000 miles
yeah i took the timing back even more and it reduced it a bit but now the timing is well retarded, there should be no need the octane of our fuel 98 is far higher than the stuff u guys use.
What would be the effects of my fuel pump producing the incorrect pressure?? I have a feeling it could be the pump too high oor too low pressure
Old Oct 26, 2002 | 10:25 AM
TurboInteg95's Avatar
so all you have done with your AFC is -35% across the board on the fuel section? Doesnt the AFC hack involve changing the tps correction in relationship to boost?
Old Oct 26, 2002 | 10:54 AM
blufke's Avatar
Default Re: What the hell!!! (TurboInteg95)
shouldnt adding more fuel stop the detonation?
Old Oct 26, 2002 | 01:40 PM
filetofit
Guest
Posts: n/a
You'll want to modify your TPS signal so that you go into open loop earlier, it's possible with the hack to run closed loop while boosting under partial throttle which would cause problems with detonation.
NirVTEC
Jun 30, 2006 09:07 AM
CMCivicSI
Jan 8, 2006 12:07 AM
mildly.interesting
Oct 27, 2004 04:40 PM
deacs
Oct 2, 2002 01:13 PM
