AFC Hack not working right
Old Oct 26, 2002 | 08:36 PM
KoRE's Avatar
Default AFC Hack not working right
Hey my AFC hack is still really rich and bogs even at -45 all across the board
but when it boost the prs stays a -773 on the AFC but my boost gauge shows boost like 5 pounds(still not pushing it)
how did you guys secure your connections? i soldered some but the Map sensor has the male and female fittings what should i do about that?
cut the fitting and just solder them?
thanks any help is appreciated
EDIT: also this was my 500th post
[Modified by KoRE, 11:37 PM 10/26/2002]
Old Oct 26, 2002 | 08:44 PM
TurboCRVTEC's Avatar
Default Re: AFC Hack not working right (KoRE)
on my car i will never use anything other than solder to connect wires. i think anything else is junk. of course, go ahead and solder them that way you KNOW its not a wiring problem
Old Oct 27, 2002 | 08:36 AM
KoRE's Avatar
Default Re: AFC Hack not working right (TurboCRVTEC)
k any one else?
Old Nov 7, 2002 | 08:37 PM
racingsoul's Avatar
well, mine isn't working right either and I soldered everything. mine is running too lean and mani psi does show positive with boosting and it does correspond to my boost gauge. what type and size injectors are u running?
[Modified by racingsoul, 5:38 AM 11/8/2002]
Old Nov 7, 2002 | 08:48 PM
KoRE's Avatar
Default Re: AFC Hack not working right (racingsoul)
sorry this is an old post i am using dsm injectors.... the afc hack wasn't working but my map sensor was broken and still is but i have an EFI PMS now and it did wonders IDLE is PERFECT, Normal driving Awesome, and gas mileage is back to normal 125 per fill up was not good.
Old Nov 15, 2002 | 08:39 AM
Fatty_1775's Avatar
kore- what is your setup? How much was your efi pms and was it hard to tune? Did you do it yourself? Thanks.
Old Nov 15, 2002 | 03:43 PM
KoRE's Avatar
Default Re: AFC Hack not working right (import_racer)
i just bought it but i'm gonna be selling it for 450 soon since i just got into a car accident her fault totaled my car...
i tuned it my self it's great...
it's for OBD1 and comes with everything even the injector driver so you don't need a resistor box....
VTC_CiViC
Aug 14, 2003 08:42 AM
zojirushi
Dec 22, 2002 08:15 AM
filetofit
Sep 4, 2002 11:30 AM
asianspeed
Aug 22, 2002 09:12 PM
vtecsiqt
Jun 30, 2002 09:43 PM
