pics of 3 Bar map sensors!?!?!?!
Old Oct 24, 2002 | 06:09 PM
Boostless97Lude
Guest
Posts: n/a
Default pics of 3 Bar map sensors!?!?!?!
alright, i searched and just found the same topics over and over, and none of them really helped.
ok, i just want to see some pics of how you guys have mounted your 3 bar map sensors, and what you have done to to get a readig on them. i wasthinking of making some sort of plate with a nipple on each side to replace where the factory one goes, have one go into the hole where the old sensor was with a straight pass thru to the other side where i can attach a vacuum line, or maybe even bore the hole out and rap new holes to screw down onto the factory location
anyways, i would LOVE to see some pics, and hear some good suggestiuons on how to mount it.
Old Oct 24, 2002 | 06:15 PM
VaporTrail's Avatar
New User
Default Re: pics of 3 Bar map sensors!?!?!?! (Boosted97Lude)
we usually leave the OEM sensor in place to plug the hole, and run a vaccum line off the intake manifold (or TB, if available) to the sensor, mounted on the firewall usually.
Old Oct 24, 2002 | 07:45 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: pics of 3 Bar map sensors!?!?!?! (VaporTrail)
i'd still kinda like to see some pics though. ttt
Old Oct 24, 2002 | 07:58 PM
boostaholic's Avatar
Here you go :
Old Oct 25, 2002 | 05:28 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: pics of 3 Bar map sensors!?!?!?! (boostaholic)
seems simple enough... thanks.
Topdawgg
Jun 25, 2007 10:02 AM
victoriasamantha
Aug 21, 2005 03:03 PM
fafsa
Dec 17, 2004 03:23 PM
integramic
Sep 7, 2004 01:44 PM
94cxhybrid-T
Sep 11, 2002 10:17 PM
