Is a Walbro fuel pump needed?
Old Oct 24, 2002 | 09:56 PM
Precision DC4's Avatar
Default Is a Walbro fuel pump needed?
I plan on turboing my LS, running around 12 psi on stock internals, 450cc injectors, with a Hondata fuel management. I was reading on the hondata site, and I came under the impression that with Hondata, if you have bigger injectors, higher pressure fuel pumps were not needed. Is this the case? TIA
http://www.hondata.com/techfuelpump.html
Old Oct 24, 2002 | 09:58 PM
fire7882's Avatar
Default Re: Is a Walbro water pump needed? (BlackIntegraLS)
your title says water pump. A larger fuel pump with large injectors isn't necessary, but recomended.
Old Oct 25, 2002 | 06:23 AM
Default Re: Is a Walbro water pump needed? (fire7882)
ok, so then what would be recommended? the 255 lph pump or the 255 lph high pressure? I've been hearing about problems with idle with the high pressure, and I was wondering if it would be a problem.
Old Oct 25, 2002 | 09:18 AM
fire7882's Avatar
the high pressure pump will only be needed if you are running a fmu setup. if you are using larger injectors with the hondata, smc or afc, the regular 255lph pump will be more than enough.
[Modified by fire7882, 1:19 PM 10/25/2002]
turbolsvtecej1
Sep 7, 2014 04:06 PM
kabaroo
Jul 9, 2004 11:06 PM
sneakypete
Jul 27, 2003 10:01 AM
HybridCoupe
Jul 6, 2002 04:44 AM
LEON
Apr 16, 2002 06:51 AM
