Overheating (another thread)
Old Oct 28, 2002 | 05:30 AM
senpai's Avatar
Default Overheating (another thread)
-The climate here is now cold.
-I recently changed the thermostat.
-I use Redline Water Wetter.
-It does not overheat at idle.
-Fan is wired to be on ALL the time.
-I let the car run with the cap off for a couple minutes.
This cold morning, it was overheating when I drive. If I stop, it seems to go back to normal. I pulled off to the side and felt the hoses. The upper hose is warm/hot but the lower hose is cold to the touch. That must be a problem. Is Water Wetter bad for cold climates?
Help me out...car can still boost and all that crap
[Modified by maztur, 8:31 AM 10/28/2002]
Old Oct 28, 2002 | 05:36 AM
senpai's Avatar
Default Re: Overheating (maztur)
I found this from Redline's website:
FREEZING POINT DEPRESSION
Red Line WaterWetter® does not significantly reduce the freezing point of water. If the vehicle will see freezing temperatures, an antifreeze must be used. Water expands approximately 9% upon freezing which can cause severe engine damage. Even in summertime, the use of air-conditioning can blow freezing air through the heater and cause freezing of the heater core unless approximately 20% antifreeze is used.
I use water+water wetter. Hmmmm...
[Modified by maztur, 8:37 AM 10/28/2002]
Old Oct 28, 2002 | 11:32 AM
madman604's Avatar
either water pump is bad or thermostat is stuck
Corksil
30
Dec 10, 2017 05:08 PM
93sidelsolvtec
Oct 8, 2006 08:32 PM
thenick
Sep 5, 2006 09:44 PM
Hondaciv95VX
Jan 13, 2005 07:21 PM
forksports
Jan 17, 2004 09:32 AM
