HP limits of walbro 255lph?
Old Oct 24, 2002 | 06:47 PM
*Boostwerks*'s Avatar
Default HP limits of walbro 255lph?
What would be the biggest injector/maximum HP that the walbro 255lph pump can support?
(and I did a search BTW)
Thanks
Old Oct 24, 2002 | 06:54 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: HP limits of walbro 255lph? (Bryson)
i made 380whp with a walbro gss317 in a previous setup.
Old Oct 24, 2002 | 09:42 PM
Default Re: HP limits of walbro 255lph? (turbotypeR)
anyone else?
Old Oct 24, 2002 | 09:57 PM
texan's Avatar
Technically, you can make about 600 hp at .6 BSFC on the 255lph Walbro (which is about what you'd expect to run on a highly boosted turbo 4 cylinder). You'd need around 1300cc injectors though, which wouldn't work very well for anything but high RPM and high boost running (read: hard to make idle). What you'd need to do is run 8 injectors and get the size down to about 550-650cc and preferrably have a standalone that activates the secondary set of injectors only when needed. This setup would provide mixture quality near stock and still allow flow rates up to ~600hp. Oh, and all this was calculated with 35-40 psi of fuel pressure, if you jacked the fuel pressure up over 80 you'd drop the maximum amount of power to 400hp or lower (depending upon which Walbro you use, the 317 or the 342), but also lower your necessary injector size. Does that answer your question?
Old Oct 24, 2002 | 10:16 PM
Default Re: HP limits of walbro 255lph? (texan)
Yes it does.....
Thank you
turboman2.2
Nov 30, 2010 02:56 PM
S2KP
Mar 11, 2010 08:52 PM
karmadhi
Oct 23, 2009 01:09 PM
Doostur
Sep 17, 2007 08:58 PM
Odiedogcx
Nov 13, 2005 12:18 PM
