what rpm range creats boost?
Old Oct 26, 2002 | 05:40 PM
bluedelsol's Avatar
Default what rpm range creats boost?
at what rpm whould a turbo start to produce boost? how many psi of boost would 2,400 rpm's produce?
Old Oct 26, 2002 | 05:50 PM
The_Head's Avatar
Default Re: what rpm range creats boost? (bluedelsol)
It depends on the size of the Turbo and many other things.
Old Oct 26, 2002 | 05:57 PM
bluedelsol's Avatar
Default Re: what rpm range creats boost? (xThexHeadx)
i am looking at some high speed electric motors to make a custom electric turbo (i know what your thinking "go with a real turbo, electric ones will break you engine)but this is a custom one witch i am making the housing and METAL fins (no plastic involved). i found one 3 speed auto shifting motor that gets up to 1750rpm's and also found a helper motor for bicycles that is one speed that gets up to 2,400rpm's, i think i'm going to go with the one speed since i'd rather not have a turbo that shifts. lol
Old Oct 26, 2002 | 06:18 PM
bluedelsol's Avatar
somebody help me out please
[Modified by bluedelsol, 3:18 AM 10/27/2002]
Old Oct 26, 2002 | 06:41 PM
bluedelsol's Avatar
Default Re: what rpm range creats boost? (Transition)
i'm not re-inventing it, i'm up-grading it. giving it a little boost.lol
Old Oct 26, 2002 | 07:23 PM
Loco Honkey's Avatar
No.
Go read some books.
Old Oct 26, 2002 | 08:46 PM
dustin's Avatar
Default Re: what rpm range creats boost? (House of Boost)
Uhh, you're going to spin the compressor with an electric motor?
You do know that engine rpm has nothing to do with turbine shaft rpm, right? Turbos routinely spin at 60,000-100,000 rpm.
Old Oct 26, 2002 | 09:05 PM
MiraiZ's Avatar
Default Re: what rpm range creats boost? (dustin)
not the electric turbo thing again!...
Old Oct 26, 2002 | 09:15 PM
Mase's Avatar
Default Re: what rpm range creats boost? (MiraiZ)
I love these posts
Old Oct 26, 2002 | 09:54 PM
M.A.R.C.'s Avatar
Default Re: what rpm range creats boost? (Mase)
I love these posts
i hate these posts... although... electric turboz 0wn
Old Oct 26, 2002 | 10:24 PM
rjardy's Avatar
Default Re: what rpm range creats boost? (CivicRyda2k)
i say go with the TOROcharger!
Rob
Old Oct 26, 2002 | 10:30 PM
wzcb08's Avatar
You know you can save yourself a lot of time if you just go to ebay and buy your electric turbo charger there.
Old Oct 26, 2002 | 10:31 PM
sutrusu's Avatar
Default Re: what rpm range creats boost? (wzcb08)
uhhh 1700 rpms? do you have any idea how fast a turbo spins?!!
Old Oct 27, 2002 | 01:20 AM
Achenar's Avatar
Dude, you might as well just connect a pipe from your throttle body to your subwoofer box port. You'll prolly get 3x the MAD POWAH over a fan spinning at 1750 RPM's.
-a
Old Oct 27, 2002 | 07:19 AM
BlueShadow's Avatar
WHAT THE HELL!?!?!?!
**punches hole into monitor**
Old Oct 27, 2002 | 07:21 AM
falcongsr's Avatar
What is this crap?
Default Re: what rpm range creats boost? (BlueShadow)
ahaha
as for the Torocharger...toro = bull so you have the bullshitcharger.
how appropriate.
Old Oct 27, 2002 | 08:19 AM
FMXer's Avatar
Default Re: what rpm range creats boost? (falconGSR)
Since you want to know how fast the turbo is spining, and i have been through this quest also...A rough sum of 90K to 125K RPM's.
You would be impeading the airflow to the engine @ 1750RPM's
Sorry.
Old Oct 27, 2002 | 08:48 AM
Vanilla Ic3's Avatar
Default Re: what rpm range creats boost? (FMXer)
Do a search... you would need an electric generator as big as your primary engine to power an electric turbocharger motor. Might as well take advantage of the exhuast pressure that just gets wasted anyways, unless you like the idea of a second engine in your trunk powering your turbo.Anything less is not going to work.
Old Oct 27, 2002 | 10:19 AM
M.A.R.C.'s Avatar
ROFL!
Old Oct 27, 2002 | 11:21 AM
ion_four's Avatar
Default Re: what rpm range creats boost? (Vanilla Ic3)
Wow, it's amazing how everyone is a goddamned electrical engineer on here
I will agree that the electric turbocharger is a waste of time, but I saw one that actually made about 3psi on a v6! and no, it wasn't that crap on ebay. it was some crazy electric motor hooked up to the compressor side of a turbo, so like a vortech supercharger, really...just had to through that out there, again
SkertySkerty
Jun 27, 2007 01:21 AM
Pengo
Sep 16, 2002 09:32 AM
OKSolSi
May 20, 2002 04:31 PM
ITR1071
May 20, 2002 10:01 AM
