t04e on a h22
Old Oct 28, 2002 | 09:32 AM
fastludeh22's Avatar
Default t04e on a h22
would this be a good choice? im new at the turbo ****. i was originally thinking a t3/t4, but that is cause it gets the most att. i figure w/the bigger h22,(bored to 89 mm) that this was a good choice. it is a ball bearing one, so i figure lag shouldn't be too bad. i was also wondering about what the max psi/hp level's i can expect from it
Old Oct 28, 2002 | 10:08 AM
ArizonaTurbo's Avatar
Default Re: t04e on a h22 (fastludeh22)
What kind of power are you looking at producing? If this is a street car and you are only looking at producing 350-375 hp, then I woudl suggest the following:
.63 A/R
Stage III
.60 A/R
60 Trim
If you want 400-500 hp go with the following specs:
.82 A/R
Stage III
.60 A/R
60 Trim
Old Oct 28, 2002 | 10:33 AM
Default Re: t04e on a h22 (TurbochargedSER)
well its kind of both, its a street driven car that i want to produce 400+ hp with...ill get the specs on the turbo later.
Old Oct 28, 2002 | 07:34 PM
t04e ball bearing, super t04e compressor 50 trim wheel, t3 exhaust turbine stage 2 48 trim...is this too small? he said it was good for 450 hp...
http://people.clemson.edu/~averma/ho...h/Turbo_01.jpg
http://people.clemson.edu/~averma/ho...h/Turbo_02.jpg
http://people.clemson.edu/~averma/ho...h/Turbo_03.jpg
what would be a good price on a slightly used one?
[Modified by fastludeh22, 11:36 PM 10/28/2002]
Old Oct 28, 2002 | 08:23 PM
Project_SOHC_EX's Avatar
When would either one of these two turbos begin to spool on the H22?
Old Oct 28, 2002 | 08:36 PM
PrecisionH23a's Avatar
Default Re: t04e on a h22 (Project_SOHC_EX)
it spools around 3500-4000 for full boost, currently its putting down 330whp at 14psi.
Old Oct 29, 2002 | 05:31 AM
That is way to small for a 2.2L. You shoudl at least get a .63 A/R turbine housing with a Stage III Turbine.
Old Oct 29, 2002 | 05:57 AM
Quiz's Avatar
The .48 A/r is rated to 400 hp and below with any Stage wheel with maybe the exception of the stage 5. TurbochargedSER is right you should be starting with the .63 A/r on a 2.2l. As far as what stage wheel to use in this, I don’t know if id personally go with the stage 3 for street but you do want to use it for track to so it's a toss up. I think 450 is obtainable with a .63 and a standard wheel but that’s just my $.02.
[Modified by Quiz, 2:06 PM 10/29/2002]
Old Oct 29, 2002 | 09:21 AM
Default Re: t04e on a h22 (Quiz)
The .48 A/r is rated to 400 hp with any Stage wheel with maybe the exception of the stage 5. TurbochargedSER is right you should be starting with the .63 A/r on a 2.2l. As far as what stage wheel to use in this, I don’t know if id personally go with the stage 3 for street but you do want to use it for track to so it's a toss up. I think 450 is obtainable with a .63 and a standard wheel but that’s just my $.02.
Sorry, but a .48 A/R housing *WON'T* support 400 hp. They die out about 250-275 hp.
Old Oct 29, 2002 | 09:51 AM
Quiz's Avatar
Billy T's vw 1.8l 20valve turbo .48 exhaust a/r stage 5 wheel 404.8 Whp off N20. Should have an article in next months SCC. Dont know how up to date this article will be. Yes we are talkinga 2.2l here and That would be a little harder to obtain with the .48 A/r . The point is we agree he sould go with the .63 A/r.
[Modified by Quiz, 2:55 PM 10/29/2002]
Old Oct 29, 2002 | 11:16 AM
DLB1994's Avatar
i say and .48 turbine can make good whp on a 1.6 or 1.8 in the low end mid power but not up top all it takes is a lot of boost to make hp
But on a h22 it wont make power past vtec i see it done many times
ill get a .82 if i had a h22
i can say that TurbochargedSER do under estimate i lot of turbo sizes
Old Oct 29, 2002 | 12:18 PM
Actually we are talking about my turbo here. If it dies out around 250-275, why is it putting out 330whp on only 14psi on my application? Its rated at 400hp.
[Modified by GudeH23a, 4:18 PM 10/29/2002]
drpoomanchu
May 26, 2007 01:32 PM
graphic
Jul 30, 2005 08:55 PM
CRiX
Jan 23, 2003 08:57 PM
blufke
Oct 9, 2002 11:23 AM
