Whoa.......running without coolant?????
Old Oct 28, 2002 | 12:48 PM
intekragsr's Avatar
Default Whoa.......running without coolant?????
I just checked my overflow tank and it was empty What the heck could this mean? I know I will sound like an idiot, but where do i fill the coolant back up? Just fill the tank? Please help me, ive never dealt with any coolant related issues before.
Old Oct 28, 2002 | 12:51 PM
I Like Boost's Avatar
Default Re: Whoa.......running without coolant????? (intekragsr)
let the car cool down, on the top of the radiator your see the overflow cap, twist that and than pull it off. fill up the radiator until it over flows. fill the reserve tank up to max line. btw its not to good for your car to run without coolent.
Old Oct 28, 2002 | 12:52 PM
EP3_05's Avatar
I would first try to find out where all the coolant is going. Then if everything checks out top off the radiator if it needs it and refill the overflow tank to anywhere between the min and max line. Then bleed the system of any trapped air. Your manual should tell you how to for your particular engine. Or if the coolant hasn't been changed in awhile do a complete flush.
intekragsr's Avatar
Default Re: Whoa.......running without coolant????? (BEe18SeAONe)
thanks a lot
Old Oct 28, 2002 | 01:17 PM
intekragsr's Avatar
Default Re: Whoa.......running without coolant????? (DOHC_VTEC)
so how could this happen???? Ive never seen a coolant leak in my garage.....
Could this have damaged my engine???
Thanks for the reply to my dumb questions.
Old Oct 28, 2002 | 03:36 PM
shadowdawn's Avatar
If there was very little or no coolant, you would overheat for sure which could lead to a warped block/head/melted pistons or any number of horrific things.... but if the car runs fine and wasn't overheating I think your engine just ate up the extra coolant in the resivour...
but like we said its a good idea to see exactly where that coolant went, check all over/under the car for leaks, do a compression test, leak down if possible.
Old Oct 28, 2002 | 04:45 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Whoa.......running without coolant????? (shadowdawn)
Yesssss. what he said ,now go do it..
Old Oct 28, 2002 | 05:25 PM
liam821's Avatar
25 Year Member
man im lucky if my car even has coolant....
liam
EJ1 guy in LBC
Sep 28, 2008 04:01 PM
hondalove888
Jun 9, 2008 06:22 PM
blemar56
Nov 28, 2006 09:28 PM
ATS*Mark
Dec 20, 2003 09:37 PM
