HELP Over Boosting
Old Oct 26, 2002 | 11:14 PM
HotRodTeg's Avatar
Default HELP Over Boosting
Ok I have a ek9 with a fully build gsr block Its got
Golden eagle sleeves
JE piston
portflow head
crower rods
and a REV HARD stage 2C turbo kit with my own t04 straight turbo
Im using the rev hard equal lenght manifold
and have a 42.5mm turbo innovation wastegate
with a Blitz SBC boost controller and the car just keeps on over boosting up to 28psi
I dynoed at 505whp @ 330 torque in 4th gear with 22psi of boost
But when we race it the boost hits up to 28psi
Im running the hondata 4b
Thanks
Old Oct 27, 2002 | 01:15 AM
liam821's Avatar
25 Year Member
Default Re: HELP Over Boosting (streetracer)
if your block is build and you have the fuel system to support it why fight the boost?
but have you try turning your boost controller down? Thats what i do when i wanna run less boost.
liam
Old Oct 28, 2002 | 06:57 AM
craesq's Avatar
The problem is probably that your wastegate cannot get rid of enough exhaust, so the exhaust has no choice but to go through the turbine = boost creep. If you are running just a 35mm wastegate (deltagate, tial) at 22psi, that might be the problem.
Old Oct 28, 2002 | 07:40 AM
ekb18c's Avatar
my guess is the boost controller.
Old Oct 28, 2002 | 08:43 AM
TeStUdO's Avatar
Default Re: HELP Over Boosting (ekb18c)
im saying wastegate if its 35mm, but if i had built internals and could handle that much boost, i wouldnt care.
nychonda
Jul 1, 2009 04:37 PM
a1320addict
Aug 12, 2005 10:47 PM
camelian
Nov 22, 2004 01:51 PM
ceemarun
May 8, 2002 12:35 AM
teamrocket si
Feb 10, 2002 02:27 PM
