Issue with inline fuel pump + fmu.. HELP!
Old Sep 23, 2003 | 06:20 PM
harryg's Avatar
Default Issue with inline fuel pump + fmu.. HELP!
The problem I'm having happens whenever I connect the inline fuel pump to the car in conjunction with the vortech 12:1 fmu.. simply put the hose that goes from the FPR to the top port on the FMU always blows off spraying fuel all over the place. When I disconnect the inline pump I never have any issues, but obviously I'm going to be starved for fuel at higher boost levels. My question is twofold..
1. Has anyone ever had this problem? What do you suggest if so/not?
2. Is it feasible to run 7psi with just the 12:1fmu, without the help of an inline fuel pump?
thanks!
Old Sep 24, 2003 | 07:01 AM
harryg's Avatar
Default Re: Issue with inline fuel pump + fmu.. HELP! (harrytg)
bump
Old Sep 24, 2003 | 07:14 AM
MaxSterling's Avatar
you need the inline pump
Old Sep 24, 2003 | 07:15 AM
DaveF's Avatar
Default Re: Issue with inline fuel pump + fmu.. HELP! (RoyFokker)
do you have the correct type of hose and hose clamps on it???
Old Sep 24, 2003 | 07:19 AM
beefpigs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RoyFokker &raquo;</TD></TR><TR><TD CLASS="quote">you need the inline pump</TD></TR></TABLE>
Did he say he has an inline pump?
harryg's Avatar
Default Re: Issue with inline fuel pump + fmu.. HELP! (2.2Lcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic &raquo;</TD></TR><TR><TD CLASS="quote">do you have the correct type of hose and hose clamps on it???</TD></TR></TABLE>
yes, in fact when I clamped the hose down very tight.. the fuel expanded in the line and blew the hose apart.. not very safe..
any other ideas?
Old Sep 24, 2003 | 07:20 AM
Default Re: Issue with inline fuel pump + fmu.. HELP! (beefpigs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beefpigs &raquo;</TD></TR><TR><TD CLASS="quote">
Did he say he has an inline pump?</TD></TR></TABLE>
can't you read, he asked if he can run boost+fmu without inline pump
Old Sep 24, 2003 | 07:22 AM
is the inline connected to the fuel relay? is it connected correctly. it should turn off in 2 seconds when you set key to acc.
Old Sep 24, 2003 | 07:24 AM
harryg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RoyFokker &raquo;</TD></TR><TR><TD CLASS="quote">is the inline connected to the fuel relay? is it connected correctly. it should turn off in 2 seconds when you set kit to acc.</TD></TR></TABLE>
yea, I was just about to mention that.. it's connected fine, I can hear it click on and off after a few seconds in acc
the fuel arrow in the pump is pointed towards the fuel rail, etc...
what the hell could it be?
Old Sep 24, 2003 | 09:33 AM
99lspwr's Avatar
Bad pump...
Old Sep 24, 2003 | 01:47 PM
harryg's Avatar
Default Re: Issue with inline fuel pump + fmu.. HELP! (99lspwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lspwr &raquo;</TD></TR><TR><TD CLASS="quote">Bad pump...</TD></TR></TABLE>
how do you figure? If it was a bad pump it wouldn't be flowing at all...
Rubixcu7
Jul 1, 2005 05:43 AM
Unjockable
Dec 24, 2004 11:05 PM
civproject14
Dec 19, 2004 10:07 PM
B18badboy
Jan 12, 2004 10:57 AM
b18tdelsol
May 19, 2002 07:09 PM
