wide band engine tunning questions?
I have the inovative tuneyourengine.com wideband 02 I did a few datta logs, and found that I am running between 14.5 to 16.0 air fuel.
thats one reason I got it on my shitty A/F guage it said I was leaning out at the top of each gear.
so hear is my question, I am trying to tune my car, should I try and get the A/F as close to 12.5 as possible? and just try to keep it their across the rpm band?
thanks for the help.
Craig
Craig
Re: wide band engine tunning questions? (DOHCarp)
Keep increasing your afc % all across the lower and higher points. Didnt your car throw a IAT code at the dyno? If so, that is a reason why your air/fuel could be off so much.
Re: wide band engine tunning questions? (boosted hybrid)
I think my car was throwing TPS, VTec oil psi.
sometimes it throws a TPS at high rpm's, but I fixed the VTec.
also I think there was something wrong with the P72 that you tuned my car with, I had the CRX turbo with only 220 hp
I ran it at the track and only got a 13.9, so I changed the ECU8 to a P30 and hit I low of 13.0, but avraged 13.2, but I am running a little lean at the top of the rpm band,
so just keep adding fuel till it comes down?
thanks
thanks
Re: (DOHCarp)
should my air fuel be a streight line of 12.5
I just about have it tuned to 12.5 across the rpm band, and the car feels very smooth.
if any one has any imput or suggestions pleas let me know.
thanks
thanks
