anyone with only PISTONS?
Old Sep 21, 2003 | 10:26 PM
B18B1DOHC's Avatar
Default anyone with only PISTONS?
anyone out there with a turbo motor with only forged pistons and no rods? how much can you boost with no rods? and can the stock Acura Integra rods hold up to 11 lbs of boost with JE 8.5:1 low compression pistons?
Old Sep 21, 2003 | 10:27 PM
rjardy's Avatar
Default Re: anyone with only PISTONS? (B18B1DOHC)
I think that, that will be about the limits on stock rods.
Rob
Old Sep 21, 2003 | 10:29 PM
sporkcrx's Avatar
Default Re: anyone with only PISTONS? (rjardy)
You might as well just get rods. Also, is it even possible to put JE's on stock rods since the wrist pins aren't freefloating?
Old Sep 22, 2003 | 11:37 PM
B18B1DOHC's Avatar
anyone?
Old Sep 23, 2003 | 05:53 AM
onetwothree's Avatar
My friend had a gsr with just 9:1 Je slugs and the most I've seen him run was 14lbs.
Old Sep 23, 2003 | 09:39 AM
gtcali's Avatar
Yeah floating wrist pins work.
I have D16 motor with LS rods on JE pistons. Does that count?
Old Sep 23, 2003 | 09:41 AM
TurboJesse
Guest
Posts: n/a
Default Re: anyone with only PISTONS? (gtcali)
Stock rods will hold ~400, but i think if i had to do the pistons i would jsut do the rods at the same time.
Old Sep 23, 2003 | 10:00 AM
zc911's Avatar
Default Re: anyone with only PISTONS? (Mpir3)
stock rods will need modified for floating pins
Basically bore out the pin hole and put a brass or was it copper, bushing in it and drill a couple oil holes
Old Sep 23, 2003 | 11:09 AM
Boltz's Avatar
Default Re: anyone with only PISTONS? (zc911)
no point of keeping rods stock if you are doing that indepth of work on a motor
you could shotpeen and cryo treat the stock rods and they would be at least twice as strong
turbo-crx
Apr 18, 2008 09:08 AM
sasinorm01
Oct 4, 2007 11:54 AM
lilpastrana
Apr 17, 2007 03:45 PM
Capt. Jimbo McSubipants
Nov 22, 2005 03:50 PM
alfee
Nov 3, 2003 09:20 PM
