FMU???
Old Sep 23, 2003 | 12:50 PM
shotty527's Avatar
Default FMU???
if i purchase an aem regulator and rail, with some 550 injectors can i remove the fmu or is it best to keep it in the system?
Old Sep 23, 2003 | 12:54 PM
silverEH2's Avatar
Default Re: FMU??? (shotty527)
no you will need something to control those bad boys at idle
Old Sep 23, 2003 | 01:05 PM
ion_four's Avatar
Your new injectors are worthless to you, unless you have a reprogrammed ecu or AFC or something else to lower the duty-cycle of the injectors. You will probably idle fine, but as soon as you get on it, you will dump fuel and run like a turd and then probably blow your motor, since you're running check-valves or a missing link and can't tune for boost...
Old Sep 23, 2003 | 01:11 PM
shotty527's Avatar
Default Re: FMU??? (ion_four)
so could install the rail and reg. and wait on installing the injectors until i get hondata?
Old Sep 23, 2003 | 02:46 PM
Cramerox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shotty527 &raquo;</TD></TR><TR><TD CLASS="quote">so could install the rail and reg. and wait on installing the injectors until i get hondata?</TD></TR></TABLE>
Yes you can. but then you can save yourself little work and put it all in at the same time. but wait till you get hondata for those injectors
Edit: make sure you get a right basemap for those injectors when you get hondata.
thefazio
Jul 4, 2006 03:17 AM
boostedlude3g
May 26, 2004 01:43 AM
Cezilla
Mar 28, 2004 08:21 AM
flarinpnoi
Mar 28, 2004 12:46 AM
SpdFrk
Aug 8, 2003 07:16 PM
