Can't someone burn an Eprom compatible with the VAFC hack?????
Old Sep 22, 2003 | 09:39 AM
hoggy's Avatar
Default Can't someone burn an Eprom compatible with the VAFC hack?????
With people burning eproms, why couldn't they adjust the timing on one as to work well with how the hack works???
Old Sep 22, 2003 | 11:21 AM
Overblown-Teg's Avatar
Default Re: Can't someone burn an Eprom compatible with the VAFC hack????? (hoggy)
Why would you bother using the afc if your burning chips?
Some guys do that with OBD0 since the only boost editor is still in pretty early development.
Old Sep 22, 2003 | 11:54 AM
TravSi's Avatar
Default Re: Can't someone burn an Eprom compatible with the VAFC hack????? (Overblown-Teg)
I use the afc to control fuel and the chip to control timing when into boost.....works well....
Old Sep 22, 2003 | 11:57 AM
hoggy's Avatar
When are we gonna see chips for boost that can be tuned with a VAFC?
Old Sep 22, 2003 | 11:59 AM
hoggy's Avatar
Default Re: Can't someone burn an Eprom compatible with the VAFC hack????? (RexSiT3)
Can you elaborate a little more about the chip you are using?
Old Sep 22, 2003 | 02:17 PM
mos's Avatar
mos
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoggy &raquo;</TD></TR><TR><TD CLASS="quote">With people burning eproms, why couldn't they adjust the timing on one as to work well with how the hack works???</TD></TR></TABLE>
They can. They do.
Old Sep 22, 2003 | 02:22 PM
hoggy's Avatar
Default Re: Can't someone burn an Eprom compatible with the VAFC hack????? (mos)
Who does it? How can I get ahold of them?
Old Sep 22, 2003 | 03:01 PM
coyote's Avatar
i would like to know too
Old Sep 22, 2003 | 06:11 PM
TravSi's Avatar
Default Re: Can't someone burn an Eprom compatible with the VAFC hack????? (coyote)
my friend took the normal n/a honda program re-wrote the timing maps so that as it went into boost it pulled timing....then i use the vafc to adjust the fuel for the 450's...made the boost transition smooth with the benefits of no timing advance as a normally aspirated would.....he has mine pull out about 1 degree per lb of boost, its mostly just munipulating the stock timing maps...took some trial and error but I now have a good setup with it.....until the full boost program is improved without the hesitations i like the use of the afc hack.....
Double Agent
Mar 17, 2006 07:43 AM
hatchedzex
Dec 23, 2004 10:48 AM
Revi
Jul 8, 2004 07:27 PM
b16booster
Sep 19, 2003 10:45 AM
dbman96
Jul 2, 2002 03:35 PM
