Stumbling hard
Old Sep 22, 2003 | 06:47 PM
Ricey McRicerton's Avatar
Default Stumbling hard
Hey guys, just got my turbo setup all on like I want it and am having problems. This is on a d16y7. It is the Greddy tdo4h-15g kit with the E-Manage and the Type 24 FMIC. In the upper range (4k+) my car sumbles and stutters hard. This only happens when I try to boost, and doesnt happen down low....(turbo spools at 2.5k) I've heard that this may be a low fuel pressure problem, but can anyone shoot me some insight?? Should'nt the E-Manage be trying to compensate for the low pressure??
Old Sep 22, 2003 | 07:05 PM
Happyman's Avatar
Default Re: Stumbling hard (Ricey McRicerton)
Maybe you didn't hook the e-manage up properly? IMO throw away the e-manage.
Old Sep 22, 2003 | 07:19 PM
Default Re: Stumbling hard (eh6turbo)
The E-Mangae is wired properly. My next question would be in the FPR department. My original Honda FPR worked on vaccum (or so I think). With boost hitting it instead of vaccum, would this cause the problems that I'm having??
Old Sep 23, 2003 | 04:11 AM
bump...need to get this fixed asap..anyone think I could not be making a strong enough spark??
Old Sep 23, 2003 | 04:17 AM
rjardy's Avatar
did the e-manage come pre programed, and do you have the suport tool?
Rob
Old Sep 23, 2003 | 05:12 AM
Default Re: Stumbling hard (rjardy)
The E-Manage was not pre-programmed (or at least I don't think) because it still had the "not street legal if removed sticker on it" and all of the ***** were set in the middle. I tuned it some last night and it is running a little better...but still stumbles. Do you see spark as a problem here?? I had been running a little rich before putting the turbo on, so now I guess that would still be my problem!
Old Sep 23, 2003 | 05:55 AM
boosted_dc2's Avatar
you should get it to a tuner before boosting hard...are you detonating maybee??? what else does your setup consist of, plugs, fuel pump, injectors etc. also boost will not hurt you fpr so thats probably not your problem,
Old Sep 23, 2003 | 06:07 AM
Default Re: Stumbling hard (hooked_up_gsr)
All I have right now is new NGK plugs (V power one step colder than stock). I don't hear any detonation...which is a good sign..but it's still stumbling hard. I tryed tuning it some, which made it a little better, but feel like fuel pressure may be my problem. Anyone agree to this?? Stock DX Fuel pump should or should not be able to handle the stock boost on a Greddy kit??
Old Sep 23, 2003 | 06:25 AM
you need a bigger fuel pump for sure, what are you running for boost??? what are your injectors??? im telling you you will be sorry if you try to tune that yourself with no wideband or anything, if your running lean you will blow your ****. but it does sound like a fuel problem, not a pressure problem but delevery, most people run a stock regulator with stock fuel pressure (with the exeption of a vortech 12:1 or similar).
Old Sep 23, 2003 | 06:37 AM
Yeah...Im running stock EX injectors on a stock DX fuel pump. Im also running the stock 5.5 psi of boost (but its closer to 4.5 at the intake due to the HUGE fmic Im running).
Old Sep 23, 2003 | 06:51 AM
your not getting enough fuel, i thought the greddy kit came with bigger injectors
Old Sep 23, 2003 | 07:02 AM
Nope..no other injectors on the Greddy kit.
Old Sep 23, 2003 | 07:15 AM
1dumbscreenname's Avatar
no injectors come with the kit. the FMU has to be mounted after the FPR or else the regulator will regulate the regulator.
Old Sep 23, 2003 | 07:19 AM
VTC_CiViC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Yeah...Im running stock EX injectors on a stock DX fuel pump. Im also running the stock 5.5 psi of boost (but its closer to 4.5 at the intake due to the HUGE fmic Im running).</TD></TR></TABLE>
I hope you didn't pay for those injectors. ALL B and D-series injectors are 240cc.
Have you tried regapping your plugs? A similar thing happend to me when I installed my MSD... got a really nasty stumble over 4k rpm in boost. I regapped the plugs and viola! ran like a charm
Old Sep 23, 2003 | 07:29 AM
Default Re: Stumbling hard (VTC_CiViC)
yeah i also forgot to mention that. my plugs were gapped to stock gap and they work. best for me. all other gaps sucked on my car.
Old Sep 23, 2003 | 10:17 AM
Default Re: Stumbling hard (1dumbassscreenname)
Nah..didnt pay extra for the injectors...just used them because they were in the intake mani that I swapped to. Thanks..Ill try regapping my plugs tonight!
variablevalve
Jun 8, 2004 04:36 PM
GZERO
Jul 28, 2003 10:01 AM
boosted6thgen
Apr 24, 2003 11:45 AM
squeaky
May 14, 2002 07:07 PM
