Running stronger pistons/rods on FI motor
1) Block is b18c1 and i plan to use JE pistons and Eagle Rods. Now, forged piston would be stronger than stock.. but what about rings? If I only messed up rings on my stock itr pistons, then wouldn't i end up in same shoes with forged pistons, - can someone explain?
2) Also, can stock itr rods take 300whp? I had no problems at 265whp.. so is it wise to stick with oem itr rods?
3)What type of coating is available for pistons? anyone done this?
Re: Running stronger pistons/rods on FI motor (vtec.dc2)
sure you can use like "jetcoat" and other coaters for pistons...
make sure you get some beefy rods..
itr rods will have to be machiend to take JE pistons. might as well save the $ on that, have stronger forged rods, and sell your ITR rods.
the rings on a JE piston are different. you will be fine with their rings.
sam
sam
Re: Running stronger pistons/rods on FI motor (94goldjungsr)
thanks, that makes sence, if i gotta modify stock, i'll just go for aftermarket..
now, what type of coating helps?
Vagitarian
09-14-2012 02:14 PM
