Deltagate problem
Old Sep 23, 2003 | 10:37 AM
xci_ed6's Avatar
Default Deltagate problem
So we (me & my friend) put in the black spring, but the WG starts to flutter at ~4.5psi and is constantly open at 5psi, sometimes, other times it will hold until 10psi. He has a Profec B Spec II (all settings at zero), but it can not open the WG at lower pressures than what the spring is set at. Any ideas? We are going to try disconecting the solonoid for the boost controller, and see what happens, but I think the results will be the same.
-Dustin
Old Sep 23, 2003 | 10:43 AM
Nextelbuddy's Avatar
Default Re: Deltagate problem (krustindumm)
boost controllers can only control boost beyond the spring setting. meaning if you have a 7 psi spring and a boost controller you can not go below 7 psi only above . hope that helps
Old Sep 23, 2003 | 11:53 AM
xci_ed6's Avatar
Default Re: Deltagate problem (nextelbuddy)
i know, the problem is that the black spring is supposed to be for 9psi, but it is not consistant at all.
-Dustin
Old Sep 23, 2003 | 11:59 AM
twkdCD595's Avatar
deltagates have the adjustment bolt in the top of them... if it is way out and still has the nut on it you may wanna try cranking it down a bit.
deltagates are notorious for needing some adjustment this way to get the prooper boost and valve closure.
try it.
Old Sep 23, 2003 | 12:01 PM
legendboy's Avatar
Default Re: Deltagate problem (twkdCD595)
how do you have it (profec b) hooked up?
Old Sep 24, 2003 | 05:46 AM
xci_ed6's Avatar
Default Re: Deltagate problem (legendboy)
the profec B is hooked up according to the directions in the manual. The settings on it seem to do nothing. I'll try messing with the adjustment bolt.
-Dustin
91integraLSVTEC
Oct 21, 2009 11:09 AM
1990hondaHF
Jan 16, 2008 11:57 AM
RTW DC2R
Jul 29, 2007 05:26 PM
95gsrturbo
Dec 4, 2003 03:48 PM
zojirushi
Jan 23, 2002 04:42 PM
