exhaust cut out quest..
Old Sep 22, 2003 | 10:15 AM
JJFreshy's Avatar
Default exhaust cut out quest..
Would it be OK to put an exhaust cut out before the first O2 sensor off the down-pipe? Or would I need to re-mount the O2 sensor before the cutout. I dont really have any room to mount the cutout anywhere else. I plan to use it at the track, I imagine I would get a "code" if I had the cutout open under normal driving..
Any help would be great..
Set up:
96 Acura Integra
18G Greddy Trubo Kit w/ blue box
Old Sep 22, 2003 | 10:46 AM
green_GSR's Avatar
Default Re: exhaust cut out quest.. (JJFreshy)
I think your setup is okay as long as your car is in open loop (WOT) when the e-cut is open. When you are at open loop (WOT), the factory ecu doesn't need the 02 sensor feedback. However, if you cruise with the e-cut open, your (factory) ecu can not detect the correct a/f, and it will throw a code and your car will run like crap.
Old Sep 22, 2003 | 11:12 AM
JJFreshy's Avatar
Default Re: exhaust cut out quest.. (green_GSR)
Thanks, what about the Greddy Blue BOx.. how does the blue box know when to add fuel. WOuld this set up effect the blue box under WOT (open loop)??
Old Sep 22, 2003 | 12:45 PM
JJFreshy's Avatar
any other opinions?
Old Sep 22, 2003 | 06:38 PM
JJFreshy's Avatar
Anyone else.. I know a alot of people are running this set up..
If anything does anyone know if I will have any issues with placing the cutout before the O2 sensor?
LVBoostedEJ1
Engine Management and Tuning
Oct 15, 2014 11:06 AM
EX-T
Mar 29, 2006 12:45 PM
Bimmerman
May 6, 2005 04:30 PM
boosted1993
Feb 7, 2004 10:36 AM
Boostless97Lude
Sep 4, 2002 07:45 PM
