Looking for opinions/advice on my engine build up
Basicaly this will be gsr block with itr stock head, no more than 300whp (i'd rather pay more money for a better piston/rod combination) - i want something trouble free and reliable..
my concern is about one cylinder, there seem to be build up near top and couple scratches (i placed blue circles around these areas).. so does it look o.k.? - don't want to re-sleeve this block
i don't want to overbore.. just keep it as close to stock diameter, and i'd like to keep 10:1 - 10:6 compression - so what are my choices?
Re: Looking for opinions/advice on my engine build up (vtec.dc2)
You should send your block and head to a machinist to check the roundness of the block and check for cracks. If everything looks good, then you can choose 0.25mm oversize forged pistons like JE if you want to stay (almost) stock bore size. JE has a lot of choices of pistons available (bore diameter, compression, etc.) so you can choose what makes sense to you.
You should also deck the block and mill the head before you put everything back together. This ensures levelness of the block and head for good headgasket sealing, and it also cleans all the crap buildup on the block and head.
Re: Looking for opinions/advice on my engine build up (green_GSR)
well.. i don't want to run cam gears - so i don't want to mill anything, unless i have to.. will these spots cause problems with sealing?
Re: (GSRswapandslow)
because i'm not after every whp.. and i won't have problems making whp i want without them..
as far as bore.. i can live with that.. but.. how great are the chance of milling the block (% wise?), maybe i'll add more layers to headgasket..
Guest
Posts: n/a
well, cam gears are a good thing to have
you can tune your power band...that's what they are there for.
you can make your car more streetable with them....
and when you get your block decked...you'll have to compensate..and it'd be better to do that with cam gears. another headgasket will just lower your compression
well.. headgasket wouldn't be to lower compression.. just to compensate for heigh loss due to milling.. i agree that cam gears can increase whp.. but in my eyes it will be another aftermarket item to worry about.. so far stock parts do the best job.. i've had fitment or maintanance issues with almost every aftermarket piece out there.. i don't want to test my car and have something fail due to cam gear timing. - so i'll just loose 2-3whp here and there.. it goes inside the engine and i can't keep an eye on it as i shift at 9000rpm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRswapandslow »</TD></TR><TR><TD CLASS="quote">
if you got something like TJ's cam gears you wouldn't have ANYTHING at ALL to worry about </TD></TR></TABLE>
i'll take that into consideration..
i'd like to hear more opinions from people on what products to go with.. and how much re-conditioning i may have to do as far as milling or overbore..
thanks everyone for help
Chris Benoit
08-10-2003 09:22 PM
