Custom Turbo Setup
Old Sep 22, 2003 | 05:00 PM
mike34655's Avatar
Default Custom Turbo Setup
I was planning to put a custom Turbo setup on my Integra GSR. I was wondering if anyone out there could help me out and let me know exactly what I would need. Thanks for your time and hope to hear from someone shortly. Thanks
Old Sep 22, 2003 | 05:21 PM
SW2001GTS's Avatar
Default Re: Custom Turbo Setup (mike34655)
im a noob with turbo too but i have a generalization of it.
1- you need a turbo of course, most likely im going to go with a T3/t4 hybrid
2- Need a wastegate Tial?
3- Turbo manifold
4- FMU - Fuel management unit?
5- Intercooler
6- all the piping
7- good management system ( Hondata )
8- The nice BOV
i believe GS-R's have high compression, so you wanna get forged low compression pistons so you can boost more, get new rods, titanium valve springs, get the block sleeved and i think you should be fine for now.... and of course theres the other misc. stuff, electronic boost controller, turbo timer, blah blah..... thats from what i know but if someone else can correct me, please do theres also a site which guides you on what you need and how to do it.... i'll post it up later
Old Sep 22, 2003 | 05:25 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
Never fear, 1 point 6 is here!
<FONT SIZE="4"><FONT COLOR="darkblue">SHOPPING LIST:</FONT> </FONT>
<FONT COLOR="purple">From Local Performance Shop</FONT>
Three 2.23 inch U-bend steel $17
One 2.5 inch 90 degree aluminized bend - $25
One down pipe flange $10
One down pipe gasket $8
One 1G blow off valve flange $10 (1st gen eclipse)
One 1G blow off valve gasket $4 (1st gen eclipse)
One 6mm gasket $3
One turbo-to-oxygen sensor housing gasket $5
One oil return line new $55 used $10 (may have to widen the opening)
One oil return gasket $1
One silicone 2.25 inch to 2 inch reducer hose $18
One foot of rubber 2.25 inch hose - $12 per foot
Nine 2.75 inch heavy duty clamps $2 each
One 3 inch heavy duty clamp - $2.50
One 1G blow off valve $90 new $5-$40 used (1st gen eclipse)
One 2G T25 Turbo - $25-$150 (2nd gen eclipse)
One 1G oxygen sensor housing $10-$20 (1st gen eclipse)
One 2G stock intercooler core - $10-$50 (2nd gen eclipse)
<FONT COLOR="purple">From Local Salvage Yard</FONT>
One HF CRX manifold $20 to $50
<FONT COLOR="purple">Local Auto Parts Store (pep boys/autozone)</FONT>
One 60 inch long .25 hard line $1.69
One 1/8 inch NPT male to male fitting $1.49
One 1/8 inch NPT femal "T" fitting $2.19
One 1/8 inch male to 1/4 inch pipe female fitting $1.49
One 1/2 inch ID rubber hose, 1 foot $1.99
One can of high temp engine paint $3.99
Four quarts of oil $9.16
One oil filter $4.15
They did mention the adapter plate in the article, but not on the list, so here is the specs on that, word for word from the article. You are going to need a custom manifold to use on a b18, shouldnt be to hard to fab one out of an exsisting stock one.
Using the HF manifold as a guide, center it on a piece of .75 x 4 x 5 inche flat steel plate that is roughly big enough to mate the header and turbo. Mark and center punch the four holes on the manifold. Drill and tap with a 10mm x 1.25mm tap .5 inch deep for all four holes, but do NOT go all the way through. If you prefer you can skip this process and weld the plate directly to the manifold. But i know some people dont have welders. Here is a pic of the adapter plate
<FONT COLOR="purple">Tools Needed</FONT>
Basic mechanics tools - Sockets, wrenches, etc.
Grinder
Tape measure
Center hole punch
Die Grinder
Drill pess/hand drill
Drill bits
2 inch hole saw
Welder
The least we spent was $225 & the most was about $560
Check out http://www.homemadeturbo.com, they have some good articles and good resources if your going to tackle this by yourself.
Old Sep 22, 2003 | 05:41 PM
ross1459's Avatar
Default Re: (1 point 6)
crx mani is not going to fit on a GSR motor though...
try a drag gen3 kit. they run t3/t4s i hear they're pretty spankin. only about $3k
Old Sep 22, 2003 | 05:49 PM
B18Flip's Avatar
Default Re: (ross1459)
I think the important question is how much do you plan on spending , it'll narrow things down
Old Sep 22, 2003 | 07:26 PM
mike34655's Avatar
Well I was planning on getting a couple of things that included the following:
Greddy Type 24 Intercooler with piping
Turbo exhuast manifold (Dont know what kind)
Downpipe (dont know what kind)
T3/T4OE Turbo .50 AR 57T Turbo
Greddy Type S BOV
35mm Tial Wastegate
Hondata (S200B)
440 RC Injectors with Clips
Greddy Profec B Spec 2 Boost Controller
Is there anything else I would need to get to complete this setup? Would I need a Turbo Timer?
Old Sep 22, 2003 | 07:36 PM
B16A1-EF9's Avatar
Default Re: (mike34655)
You should consider getting a good flowing stainless steel manifold, an equal length one. Check my site at http://www.5252motorsports.com/store/turbo.htm
All prices are in canadian funds so you'll find that we are very reasonably priced. The manifolds we carry are all Lovefab manifolds and are good up to and probably over 550whp!
Old Sep 22, 2003 | 08:03 PM
mattb16a1civic's Avatar
nice little list of misc stuff
Old Sep 22, 2003 | 08:05 PM
GSRswapandslow
Guest
Posts: n/a
OR
love fab mani
cheapturbos.com turbo
and find the rest of the **** on here
Old Sep 24, 2003 | 03:30 AM
mike34655's Avatar
Thanks for all the information.
NBPdEeCeE
Aug 17, 2007 01:12 PM
19sec beast
Mar 20, 2005 06:50 AM
JDMVTEC
Sep 29, 2003 04:07 PM
96SR-V
Feb 25, 2003 02:42 PM
