what LSD are you D-series guys using?
Guest
Posts: n/a
Ok, my car is ALMOST done...and i'm looking into LSD's and Clutches.
From all the cars i've driven and ppl i've talked to...i'm goin with the Clutchmasters stage 5. YES, i know i said stage 5. YES, i know it's a semi harsh clutch. YES, i will drive it daily. Thanks
but, to go along with it...i need an LSD.....
but who makes them for the d series tranny? The ZC lsd will fit...but where do i find one? Aftermarket???
Re: (mugensport9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugensport9 »</TD></TR><TR><TD CLASS="quote">$225!
http://66.70.247.211/TwinTracDesc.htm </TD></TR></TABLE>anyone know if this actually works?
Guest
Posts: n/a
no, that won't work well
the whole problem about them is that they use the stock spider gears. that's the damned weak link in a honda differentail...so why the **** would you want to put more stress on them?!??!?!
and quaife does make one? I couldn't ever get confirmation on that...
thanks guys!
thanks guys!
Re: (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ »</TD></TR><TR><TD CLASS="quote">Phantom slip
Quaiffe
-PHiZ</TD></TR></TABLE>
The qualife comes with an unconditional lifetime guarantee does it not??
Quaiffe
D Tranny Guru
Re: (GSRswapandslow)
You have 2 options, Kaaz or Quaife.
I went Kaaz as I am doing mostly drag racing right now. I will switch to a Quaife for road racing later.
While you can tolerate a Kaaz on the street, a Quaife would make more sense. I bark the inside tire going around shape turns under mid power. The Kaaz LOCKS up almost like a spool!!!
Location: Why so you can pretend like youre interested, FL/OK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRswapandslow »</TD></TR><TR><TD CLASS="quote">seems that $810 shipped is the going rate i've seen</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=605178
Re: (Lastgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lastgsr »</TD></TR><TR><TD CLASS="quote">anyone know if this actually works?</TD></TR></TABLE>
Those are the biggest pieces of ****. The worst purchase I have ever had. (Phatom slip I am talking here) I bought it and did a burnout in the burnout box at Joliet raceway and exploded the diff in the box. Nice embarassing tow to the pits. Better yet, nice $400 tow to home (About 90 minutes away). GSR, don't even waste your money on this piece.
Yes, quaife makes one. I have it now. They work wonders and take anything you can throw at them.
