Oil return leak
Old Sep 21, 2003 | 11:31 PM
Nameless RB26's Avatar
Default Oil return leak
The swivel on the return line from the turbo (on the oil pan) is leaking a few small drips.
I don't like it.
Is there a way to fix it?
Old Sep 22, 2003 | 01:46 AM
Default Re: Oil return leak (Nameless EJ6)
Cmon now? Any way to fix those types of fitting leaks?
Old Sep 22, 2003 | 06:56 AM
highmilehatch's Avatar
The swivel point on my 45 degree fitting on the pan leaks too.
Old Sep 22, 2003 | 08:05 AM
Default Re: Oil return leak (highmilehatch)
Damnit, has anyone fixed one before?
I'm going to gum this thing up with teflon tape today if I can't figure something out.
Old Oct 3, 2003 | 10:13 AM
White Smoke's Avatar
i my honda
Global Mod
Hate to say it but I think you guys should get um welded
Cheep insuarance
Old Oct 3, 2003 | 10:16 AM
SiRkid's Avatar
huh? the swivel of the hose end is leaking?
i would chalk that up to not being tight enough. it seals on the inside with that 45 deg angle.
if its not tight enough , no seal.
Old Oct 3, 2003 | 10:17 AM
ion_four's Avatar
Default Re: Oil return leak (si2die4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si2die4 &raquo;</TD></TR><TR><TD CLASS="quote">Hate to say it but I think you guys should get um welded
Cheep insuarance</TD></TR></TABLE>
I think the fitting is probably brazed on, are you implying that they should weld the stainless/anodized aluminum fitting?!
Old Oct 3, 2003 | 10:24 AM
BROOD's Avatar
Default Re: Oil return leak (ion_four)
Try tightening it if it is still leaking........Replace the fitting
Old Oct 3, 2003 | 11:11 AM
R6Elmo's Avatar
Default Re: Oil return leak (BROOD)
That happened to my 90 Degree fitting too. Very little though. I tightened it more and that solved it. Fittings seal with the 37 degree angle. If it's nto tight enough = leak. Try teflon tape too..could help.
Old Oct 3, 2003 | 11:29 AM
Default Re: Oil return leak (R6Elmo)
I have cleaned the joint with soap and water AND used teflon tape + light hondabond. They're very tight.
It is leaking from the joint, you cannot tighten that.
Anyways, I ordered replacements, they should be here soon...
Old Oct 3, 2003 | 12:03 PM
Foozball26's Avatar
I've got the same problem with my 45 degree fitting.
I have tried everything and still leaks from the swivel joint.
let me know if the new fitting solves it.
Also, I had an idea that the oil level is too high, but the fitting on the pan is as high up as it can physically go.
Old Oct 3, 2003 | 12:04 PM
R6Elmo's Avatar
Default Re: Oil return leak (Foozball26)
Can you tell me what brand fittings you guys are using..that way I would avoid them?
Old Oct 3, 2003 | 02:17 PM
I'm replacing with some earls fittings.. different ones though.
Get them from bakerprecision.com
I got this one:
45 degree bent tube. Part # 804610
And an AN to pipe fitting (1/2"). Part # FCM2009
I haven't recieved them in the mail yet, but I'll report back after I install them. I don't like the 45 degree swivel that comes with the drag kits.. so I got the tube swivel and a pipe fitting.
kyle h.
Dec 5, 2007 06:56 AM
Type-ARR
Nov 8, 2007 04:22 AM
mc
Dec 30, 2005 01:50 PM
Novtecdohc
Aug 31, 2005 04:29 PM
BauleyCivic
Oct 16, 2004 08:08 PM
