wastegate location >>
Old Sep 21, 2003 | 04:30 PM
platinum00's Avatar
Default wastegate location >>
i see alot of manifolds with wastegate flangs on one of the runners instead of where they merge together.
is there any downfall to not having the wastegate where it picks up the flow of all 4 cylinders instead of just one.
platinum.
Old Sep 21, 2003 | 06:34 PM
D-Man's Avatar
Default Re: wastegate location >> (platinum00)
ttt
Old Sep 21, 2003 | 06:49 PM
15psi of fun's Avatar
Default Re: wastegate location >> (D-Man)
Some say you get boost spikes or boost creep when it is on one runner that’s why they put it where they all come together.
Old Sep 21, 2003 | 06:52 PM
platinum00's Avatar
Default Re: wastegate location >> (EFrollingout)
any proof to this.
Old Sep 21, 2003 | 07:01 PM
Tinker219's Avatar
Drag manifold above 10psi= creeep, and nasty tq curves.
InlinePro manifold above 10psi= steady everything.
I used those two examples because they are similar in turbo placement, but the WG locations differ quite a bit.
And, the drag puts the WG on the #1 runner
Old Sep 21, 2003 | 07:11 PM
platinum00's Avatar
Default Re: wastegate location >> (Tinker219)
ok, well then that brings up a new question. to fix the issue of creep and crappy curves,
could you block off the wastegate flange on the runner and then run your wastegate from the downpipe flange such as this.
platinum.
Old Sep 21, 2003 | 07:14 PM
Tinker219's Avatar
Ya, thats how the turbos are designed to evacuate gas from Garret. Will be ALOT better then the WG coming off ONE runner....
Old Sep 21, 2003 | 07:32 PM
Dee's Avatar
Dee
Actually that design is not efficient since it is trying to control boost after the flow has entered the ex housing. The best method to prevent creep and have excellent control is before the ex housing entry at a location that pulls equally from all cylinders. The swing valve type housings also have a tiny outlet that is restrictive if you do not port it.
Modified by Dee at 4:05 AM 9/22/2003
Old Sep 21, 2003 | 08:51 PM
R6Elmo's Avatar
my revhard tubular manifold puts the wastegate on only one runner and it works perfectly fien for me as well as many others out there. I'm not sure why it works well compared to others.
Old Sep 21, 2003 | 08:56 PM
rjardy's Avatar
to bad you cant do that with percision turbos...
Rob
Old Sep 21, 2003 | 10:32 PM
TurboDANDEE's Avatar
Default Re: (R6Elmo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R6Elmo &raquo;</TD></TR><TR><TD CLASS="quote">my revhard tubular manifold puts the wastegate on only one runner and it works perfectly fien for me as well as many others out there. </TD></TR></TABLE>
no it does not. Drag manifold is on the #1 runner, the RevHard is placed closer to the collector area (between #1 & #2) compared to the Drag.
Old Sep 22, 2003 | 06:55 AM
DaveF's Avatar
Default Re: (TurboDANDEE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboDANDEE &raquo;</TD></TR><TR><TD CLASS="quote">
no it does not. Drag manifold is on the #1 runner, the RevHard is placed closer to the collector area (between #1 & #2) compared to the Drag.</TD></TR></TABLE>
dandee. he could be talking about the old "short" tubular version, in which the wastegate is placed on the #4 runner.
Old Sep 22, 2003 | 09:55 AM
platinum00's Avatar
Default Re: (2.2Lcivic)
ttt
Old Sep 22, 2003 | 10:39 AM
Gotcha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic &raquo;</TD></TR><TR><TD CLASS="quote">
homicydalboy
Jun 4, 2007 06:12 PM
Meet07
Mar 28, 2006 07:23 AM
prcrx124
May 16, 2005 01:40 PM
H22CB7
Apr 23, 2004 06:08 PM
NyQuiL
Jul 15, 2003 11:14 PM
