hooking up a MBC?
Old Sep 23, 2003 | 12:00 PM
fastcivicboy's Avatar
Default hooking up a MBC?
I just made a Manual boost controller and was wondering how yall would recommend hooking it up! Like were I should run the vac lines. Thanks for the help!
Old Sep 23, 2003 | 12:09 PM
gritsak's Avatar
Default Re: hooking up a MBC? (fastcivicboy)
between the wastegate and boost source
Old Sep 23, 2003 | 01:07 PM
well see look how he says to hook it up at the bottom of the link the picture/digram http://www.geocities.com/chmwatson/FAQs/mbc.html is it ok to hook it up like that
Old Sep 23, 2003 | 01:31 PM
gritsak's Avatar
Default Re: (fastcivicboy)
yeah thats fine....on my car and my friends we drilled a hole in the intercooler pipe and screwed a brass nipple fitting from lowes in and put jbweld around it to seal...then ran a line directly from the nipple to the boost controller instead of using the line from the bov....eitherway it just needs a good pressure signal...then the other side into the wastegate as shown
Old Sep 23, 2003 | 03:05 PM
Cramerox's Avatar
Default Re: (gritsak)
yeah anywhere after the IC will be good. that way it compensates for any boost drops.
Project_EK
Apr 22, 2009 09:13 AM
Silva Bullit DC4
Jan 17, 2008 02:06 PM
wanttorace
Jun 5, 2003 09:17 PM
20lb.teg
Sep 14, 2002 02:28 PM
austrian type-R
Apr 18, 2002 10:00 PM
