450 cc noob ?
Old Sep 21, 2003 | 12:18 PM
nhez's Avatar
Default 450 cc noob ?
correct me if i'm wrong, i just want to double check. i'm putting walbro 255 and 450s. to do the 450s i have to get new seals and bore them for proper fitting and once put on, i don't need to put resistors/box since my rex got one already. last thing is i do need to convert my injector clips to obd 1 right or i don't have to? that's the only part i'm buggin with. thanks
Old Sep 21, 2003 | 12:56 PM
inspyral's Avatar
You should be able to bore out your stock seals, or might not have to touch them at all. You shouldn't have to do anything wiht the clips if your car originally had peak and hold injectors.
Old Sep 21, 2003 | 01:06 PM
nevin's Avatar
Also make sure you dont just put them in. You need somthing to control them like an afc or standalone, otherwise you will run rich and foul your plugs.
Old Sep 21, 2003 | 01:28 PM
nhez's Avatar
Default Re: (inspyral)
i have a 88 crx, so my car being a obd0 has nothing to do with the injectors being an obd1? thanks for the reply
Old Sep 21, 2003 | 01:37 PM
nhez's Avatar
Default Re: (nevin)
afc hack is the route i'm going with. so it would be better to put my pump, injectors and afc controller all at the same time? would it be bad if i run the 450s and 255 pump on a fmu set up?
Old Sep 21, 2003 | 01:56 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (nhez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nhez &raquo;</TD></TR><TR><TD CLASS="quote">afc hack is the route i'm going with. so it would be better to put my pump, injectors and afc controller all at the same time? would it be bad if i run the 450s and 255 pump on a fmu set up?</TD></TR></TABLE>
Yes put it all on at the same time!
Yes it would be horrible if you ran 450s and a intake pump on FMU set up.
I would adivse hondata.
Old Sep 21, 2003 | 04:17 PM
nhez's Avatar
i can't afford hondata for now. going with the hack, unless anybody knows anything better about the same price tag as the hack.
93grayeg
Jan 9, 2010 02:19 AM
mortificationrock
May 3, 2007 09:33 PM
robbizza
Oct 31, 2006 11:47 AM
EF_LSVtec
Apr 15, 2004 06:41 AM
japrex
Nov 27, 2003 11:46 PM
