HELP OVERHEATING!!!!!!
Old Sep 23, 2003 | 10:28 PM
thor559's Avatar
Default HELP OVERHEATING!!!!!!
I HAVE A DRAG 3 KIT..ITS A GARRET T3,FMU( CHEAP..I KNOW) SETUP..
ITS 98 LS..RUNNIN ON STOCK RADIAR, FULLY BUILT BOTTOM END(EAGLE H BEAM, CUSTOM PISTON 9:1, BORE 84MM, DARTON SLEEVE,)
I JUST DROP MY ENGINE THIS WEEKEND AND IT OVERHEATS LIKE HELL.....I CANT EVEN GO AROUND THE BLOCK(NO BOOST)....IS THERE A SENSOR I HOOKED ON WRONG OR WHAT AM I DOING WRONG????......HELP PLZ....
Old Sep 23, 2003 | 11:38 PM
greekspeed's Avatar
Default Re: HELP OVERHEATING!!!!!! (thor559)
did u bleed the radiator system after refilling the coolant to make sure that there is just coolant/water in ur whole cooling system and not any air?
that causes overheating most of the time.
Old Sep 23, 2003 | 11:54 PM
RangerDan's Avatar
Default Re: HELP OVERHEATING!!!!!! (greekspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greekspeed &raquo;</TD></TR><TR><TD CLASS="quote">did u bleed the radiator system after refilling the coolant to make sure that there is just coolant/water in ur whole cooling system and not any air?
that causes overheating most of the time.</TD></TR></TABLE>
What he said.
Old Sep 24, 2003 | 05:49 AM
Foozball26's Avatar
Default Re: HELP OVERHEATING!!!!!! (RangerDan)
did you evem fill up the radiator?
Old Sep 24, 2003 | 06:21 AM
silverEH2's Avatar
Default Re: HELP OVERHEATING!!!!!! (Foozball26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Foozball26 &raquo;</TD></TR><TR><TD CLASS="quote">did you even fill up the radiator? </TD></TR></TABLE>
LOL....
Doh!
32
May 16, 2007 08:22 PM
-Championship-
Nov 26, 2006 07:14 PM
CDtegGo
Aug 27, 2006 02:22 PM
gsrcxhatch
May 11, 2006 07:37 PM
drumsy
Sep 12, 2002 07:14 AM
