new here!! i would like your opinions..
Hi! i'm new to this site. but not to honda's. mostly crx's. i have some questions to ask!!!
i have a 1990 crx si with a B20z, zex dry kit, and other aftermarket parts...
my questions are:
-i have a chance to buy a *used* gerret T-4 turbo setup(BOV, intercooler, piping, hoses, etc...) for $1300. then i'm going to do the V-afc hack with 450cc injectors(which i got off this site and the drop shops site. thanks!). i'm going drag racing oct. 4.
i have zero experiance on turbo's. some knowledge on turbo's(stuff i read on here and homemadeturbo).
should i just dive into the turbo get everything i need? hook it up by oct. 4 and go race? or should i just wait? and over the winter. do all my research on turbos and what not. and either buy as i go? or in the spring buy the turbo setup(by then i'll have some good idea what i'm doing)?
there is no one in my area that has experiance with Honda's. so i would be doing this on my own! plus the nearest dyno is 4 hours away. so i can't do that!
is it realistic that i can bolt the turbo setup in, wire the V-afc, and put the injectors in. with NO experiance!!! and have it run good(with out blowing up my engine)???
any help would be helpful!!!
thanks
my questions are:
thanks
Re: new here!! i would like your opinions.. (1SIKCRX)
October 4th is pretty close... If you stick around honda-tech you'll learn everything you need That's what I've done
Re: new here!! i would like your opinions.. (5thgencivic)
welcome...meet the search function, and make it your new best friend...everything you need to know is just a search away https://honda-tech.com/zerosearch
Re: new here!! i would like your opinions.. (ha illuminato un)
i'm not sure if you read the hole post! but i do say that i learned a thing or too from this site!!! which indicates that i did a search prier to posting my post!!!
all i need to know is:
if it is realistic that i can bolt the turbo kit up, wire the V-afc, etc... with no experiance with turbos? and without a dyno? or help from someone that knows what there doing?
thanks
thanks
Re: new here!! i would like your opinions.. (silverEH2)
ok it looks like i'll go back to the search feature!!! any suggestions on what i should type in to get the answers i'm looking for?
thanks
thanks
well i've been useing the search feature for like a half an hour now. and i can't seem to find anything that answers my questions!!!
can someone just step up to the plate and swing away with some answers?!?!
thanks
thanks
Re: new here!! i would like your opinions.. (2.2Lcivic)
well my main question is:
i live in plymouth, Maine.
thanks
thanks
no experience is fine, but with no knowledge on the various procedures I wouldn't even try attempt it...but judging by the way you're aksing you should do some more searching...the FI forum has TONS of info that will help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SIKCRX »</TD></TR><TR><TD CLASS="quote">well my main question is:
thanks</TD></TR></TABLE>
AccludeDreamer
09-18-2009 09:01 PM
