can it be the gasket??
Old Sep 22, 2003 | 10:19 AM
viet4gvtec's Avatar
Default can it be the gasket??
my prelude doesn't seem to make hp after 4k rpm . i check it today , the gasket is leaking bad( the one from the manifold to wastgate) can this be the prolem
i feel turbo spool up at around 3k rpm , car pulling hard then power drop after that
Old Sep 22, 2003 | 10:44 AM
thid92's Avatar
can I haz?
Default Re: can it be the gasket?? (viet4gvtec)
i am not an expert but i would have to guess that your waste gate is opening up to early. just my guess though.
Old Sep 22, 2003 | 10:46 AM
viet4gvtec's Avatar
anyone???
Old Sep 22, 2003 | 11:43 AM
thid92's Avatar
can I haz?
doh. i didnt even read that your gasket was leaking, thats the problem. you wont spool up to full boost because the leaking gasket is working like a wastegate set at a lower boost. so you will see a lower boost. thats why you'r not feeling the same power as you had before.
Mr. Vapor
Jul 30, 2006 06:19 AM
mrrugsr
Mar 11, 2006 10:53 PM
rondigs
Feb 28, 2005 04:49 PM
Bspec18
Jul 3, 2003 09:32 PM
GSRwBOOST
Aug 3, 2001 03:44 PM
